Article ID : 00206670 / Last Modified : 27/06/2019
Closed Caption/Subtitle
    IMPORTANT: This article applies only to specific products. Check the Applicable Products and Categories section of this article.
    Subtitles are typically transcriptions of the audio portion of content displayed on the TV screen. They include sound effects and scenic narration, but whether non-speech elements are available depends on the content.
    Display subtitles on the TV screen
    The subtitle feature is enabled by pressing the SUBTITLE (CC) button on the TV remote control.
    Content for which subtitles are available are as follows:
    • TV broadcasts: Subtitles may not be available for some TV broadcasts.
    • Movies: Subtitles may not be available for some movies.
    • Apps: Some apps, such as Netflix, enable subtitles by using their own settings menu instead of pressing the SUBTITLE (CC) button on the TV remote control. In addition, some apps can change the text size and colour.
      NOTES: Visit the support site of the apps for detailed information, including how to enable features.
