Article ID : 00112938 / Last Modified : 27/09/2018
Non-Android TV stuck in reboot loop and ON/OFF power LED blinks 8 times (2012 Models)
    You may be experiencing a rebooting loop on your TV - illustrated by the ON/OFF power LED blinking 8 times. This is affecting only 2012 Internet Internet TVs.
    Some customers have reported the below instruction to potentially bring the situation back to normal.
    Check this page regularly for updates.
    Depending on how your TV is connected to the Internet, please use one of the following recovery methods:
    Wired Ethernet LAN connections
    1. Unplug the TV power cord from the electrical outlet
    2. Disconnect your Ethernet cable from the TV
    3. Plug the power cord back in to the electrical outlet
    4. Turn on your TV
    5. Perform a factory reset:
      • Press and hold the up arrow button on the remote control.
      • While holding the up arrow button, press and release the Power on button on the side of the TV.
        Reset will appear momentarily on the lower left hand corner of the TV
      • Release the up arrow button on the remote control and wait for the TV to reset
    6. After the Reset message appears, allow the TV to reset. Do not press any buttons on the remote control or on the TV and do not make any other adjustments for 1 minute.
    7. Upon completion, unplug the power cord from the electrical outlet
    8. Allow the TV to remain without power for 10 seconds
    9. Reconnect your Ethernet cable to the TV
    10. Plug the power cord back in to the electrical outlet
    11. Turn on the TV.
      NOTE: The initial setup screen displays if the above procedures were performed correctly
    12. Follow the on-screen instructions to complete the initial set up
      IMPORTANT: If the reset did not complete successfully, disconnect all devices from the TV, and then repeat the procedure from step 1.
    Built-in Wireless LAN connections
    2. Turn off your Wi-Fi router
    4. Turn on your TV
    9. Turn on your Wi-Fi router
    11. Turn on the TV.
    USB Dongle Wireless LAN connections
    2. Disconnect your USB dongle from the TV
    4. Turn on your TV
    9. Reconnect your USB dongle to the TV
    11. Turn on the TV.
    This information is only applicable for the following 2012 models:
    KDL-22EX550
    KDL-22EX553
    KDL-22EX555
    KDL-26EX550
    KDL-26EX553
    KDL-26EX555
    KDL-32EX650
    KDL-32EX653
    KDL-32EX655
    KDL-32HX750
    KDL-32HX751
    KDL-32HX753
    KDL-32HX755
    KDL-32HX757
    KDL-32HX758
    KDL-32HX759
    KDL-40EX650
    KDL-40EX653
    KDL-40EX655
    KDL-40HX750
    KDL-40HX751
    KDL-40HX753
    KDL-40HX755
    KDL-40HX756
    KDL-40HX757
    KDL-40HX758
    KDL-40HX759
    KDL-40HX75G
    KDL-40HX850
    KDL-40HX853
    KDL-40HX855
    KDL-46EX650
    KDL-46EX653
    KDL-46EX655
    KDL-46HX750
    KDL-46HX751
    KDL-46HX753
    KDL-46HX755
    KDL-46HX756
    KDL-46HX757
    KDL-46HX758
    KDL-46HX759
    KDL-46HX75G
    KDL-46HX850
    KDL-46HX853
    KDL-46HX855
    KDL-55HX750
    KDL-55HX751
    KDL-55HX753
    KDL-55HX755
    KDL-55HX75G
    KDL-55HX850
    KDL-55HX853
    KDL-55HX855
    KDL-55HX950
    KDL-55HX953
    KDL-55HX955
    KDL-65HX950
    KDL-65HX953
    KDL-65HX955
    KD-84X9005
