Article ID : 00177806 / Last Modified : 11/11/2019
Wall mounting - compatible Wall-Mount Brackets and screw hole distance measurements for BRAVIA TV (2015-2018 models)
    Please see the following chart and check the compatible Wall-mount Bracket for your TV.
    WARNING: There is a risk of personal injury.
    • For product protection and safety reasons, Sony recommends that the mounting of your TV on the wall is performed by Sony dealers or licensed contractors.
    • For Safety reasons and to ensure a correct installation, please follow the Wall-mount Bracket Operation Instructions, the TV Setup Guide and the following instructions.
    To see the compatibility chart
    Compatibility chart
    About the Strength of Walls
    About Screws
    • The screw hole distance measurements: Width x Height expressed in mm
      The diagram shows the rear side of the BRAVIA TV.
      back side of the BRAVIA TV
      [A] W (width)
      [B] H (height)
      [C] screw holes
      NOTE:
      • In some models of BRAVIA TV, the screw hole distance measurements (W x H) conform to the VESA Mount Standard, but the number and depth of the screw holes do not.
      • Sony cannot guarantee the use of a third party wall mount bracket to mount the BRAVIA TV.
      • For more detailed information and precautions about wall mounting, see the manuals of your TV and wall mount bracket.
    • AC Power adapter size: Width x Height x Depth expressed in mm
      An AC Power adapter comes with some models. The diagram shows the AC Power adapter size compatibilities (W x H x D) in the Compatibility chart.
      Ac Power adapter size
      [A] W (width)
      [B] H (height)
      [C] D (depth)
    Compatibility chart
    2018 models
    Series Name
    Model Name
    Inches
    Compatible Wall-Mount Bracket
    Screw hole size
    (W x H) mm
    Screws (Supplied with Wall-Mount Bracket)
    Length of power cord (mains lead)
    Weight of TV without Stand
    AF8 SeriesKD-65AF865SU-WL450 *1300x300+PSW 6x20, +PSW 6x502 m24.4 kg
    KD-55AF855SU-WL450 *1300x200+PSW 6x20, +PSW 6x502 m18.7 kg
    AF9 SeriesKD-65AF965SU-WL450 *1400x200+PSW 6x20, +PSW 6x502 m27.2 kg
    KD-55AF955SU-WL450 *1400x200+PSW 6x20, +PSW 6x502 m23.8 kg
    XF9005 SeriesKD-75XF900575-400x300-1.5 m35.0 kg
    KD-65XF900565SU-WL450 *1300x300+PSW 6x20, +PSW 6x501.5 m24.5 kg
    KD-55XF900555SU-WL450 *1300x300+PSW 6x20, +PSW 6x501.5 m18.2 kg
    KD-49XF900549SU-WL450 *1200x200+PSW 6x20, +PSW 6x501.5 m13.6 kg
    XF8796 SeriesKD-65XF879665SU-WL450 *1300x300+PSW 6x20, +PSW 6x501.5 m25.6 kg
    KD-55XF879655SU-WL450 *1300x200+PSW 6x20, +PSW 6x501.5 m19.1 kg
    KD-49XF879649SU-WL450 *1200x200+PSW 6x20, +PSW 6x50DC Cable length of AC adapter
    1.5 m
    Length of AC Power Cord
    0.5 m
    AC Power adapter size (W x H x D)
    (170 x 85 x 40) or (191 x 80 x 39)
    13.2 kg
    KD-43XF879643SU-WL450 *1100x200+PSW 6x20, +PSW 6x50DC Cable length of AC adapter
    1.5 m
    0.5 m
    10.8 kg
    XF8599 SeriesKD-65XF859965SU-WL450 *1300x300+PSW 6x20, +PSW 6x501.5 m25.6 kg
    KD-55XF859955SU-WL450 *1300x200+PSW 6x20, +PSW 6x501.5 m19.1 kg
    KD-49XF859949SU-WL450 *1200x200+PSW 6x20, +PSW 6x50DC Cable length of AC adapter
    1.5 m
    0.5 m
    13.2 kg
    KD-43XF859943SU-WL450 *1100x200+PSW 6x20, +PSW 6x50DC Cable length of AC adapter
    1.5 m
    0.5 m
    10.8 kg
    XF8596 SeriesKD-85XF859685-400x400-2 m44.1 kg
    KD-75XF859675-400x300-1.5 m38.9 kg
    KD-65XF859665SU-WL450 *1300x300+PSW 6x20, +PSW 6x501.5 m25.6 kg
    KD-55XF859655SU-WL450 *1300x200+PSW 6x20, +PSW 6x501.5 m19.1 kg
    KD-49XF859649SU-WL450 *1200x200+PSW 6x20, +PSW 6x50DC Cable length of AC adapter
    1.5 m
    0.5 m (Russia: 1.5 m)
    13.2 kg
    KD-43XF859643SU-WL450 *1100x200+PSW 6x20, +PSW 6x50DC Cable length of AC adapter
    1.5 m
    0.5 m
    10.8 kg
    XF8588 SeriesKD-65XF858865SU-WL450 *1300x300+PSW 6x20, +PSW 6x501.5 m25.6 kg
    KD-55XF858855SU-WL450 *1300x200+PSW 6x20, +PSW 6x501.5 m19.1 kg
    KD-49XF858849SU-WL450 *1200x200+PSW 6x20, +PSW 6x50DC Cable length of AC adapter
    1.5 m
    0.5 m
    13.2 kg
    KD-43XF858843SU-WL450 *1100x200+PSW 6x20, +PSW 6x50DC Cable length of AC adapter
    1.5 m
    0.5 m
    10.8 kg
    XF8577 SeriesKD-65XF857765SU-WL450 *1300x300+PSW 6x20, +PSW 6x501.5 m25.6 kg
    KD-55XF857755SU-WL450 *1300x200+PSW 6x20, +PSW 6x501.5 m19.1 kg
    KD-49XF857749SU-WL450 *1200x200+PSW 6x20, +PSW 6x50DC Cable length of AC adapter
    1.5 m
    13.2 kg
    KD-43XF857743SU-WL450 *1100x200+PSW 6x20, +PSW 6x50DC Cable length of AC adapter
    1.5 m
    0.5 m
    10.8 kg
    XF8505 SeriesKD-65XF850565SU-WL450 *1300x300+PSW 6x20, +PSW 6x501.5 m25.6 kg
    KD-55XF850555SU-WL450 *1300x200+PSW 6x20, +PSW 6x501.5 m19.1 kg
    KD-49XF850549SU-WL450 *1200x200+PSW 6x20, +PSW 6x50DC Cable length of AC adapter
    1.5 m
    0.5 m
    13.2 kg
    KD-43XF850543SU-WL450 *1100x200+PSW 6x20, +PSW 6x50DC Cable length of AC adapter
    1.5 m
    0.5 m
    10.8 kg
    XF8305 SeriesKD-70XF830570SU-WL450 *1400x300+PSW 6x20, +PSW 6x501.5 m25.6 kg
    KD-60XF830560SU-WL450 *1300x300+PSW 6x20, +PSW 6x501.5 m19.8 kg
    XF8096 SeriesKD-55XF809655SU-WL450 *1300x200+PSW 6x20, +PSW 6x501.5 m17.6 kg
    KD-49XF809649SU-WL450 *1200x200+PSW 6x20, +PSW 6x50DC Cable length of AC adapter
    1.5 m
    12.2 kg
    KD-43XF809643SU-WL450 *1100x200+PSW 6x20, +PSW 6x50DC Cable length of AC adapter
    1.5 m
    10.1 kg
    XF7596 SeriesKD-65XF759665SU-WL450 *1300x200+PSW 6x20, +PSW 6x501.5 m20.2 kg
    KD-55XF759655SU-WL450 *1200x200+PSW 6x20, +PSW 6x501.5 m16.2 kg
    KD-49XF759649SU-WL450 *1200x200+PSW 6x20, +PSW 6x50DC Cable length of AC adapter
    1.5 m
    (158 x 70.5 x 35) or (155 x 67 x 36.5)
    12.0 kg
    KD-43XF759643SU-WL450 *1100x200+PSW 6x20, +PSW 6x50DC Cable length of AC adapter
    1.5 m
    9.8 kg
    WF805 SeriesKDL-49WF80549SU-WL450 *1200x200+PSW 6x20, +PSW 6x50DC Cable length of AC adapter
    1.5 m
    1.5 m
    (137 x 60 x 30)
    11.8 kg
    KDL-43WF80543SU-WL450 *1100x200+PSW 6x20, +PSW 6x50DC Cable length of AC adapter
    1.5 m
    1.5 m
    (137 x 60 x 30)
    9.4 kg
    WF804 SeriesKDL-49WF80449SU-WL450 *1200x200+PSW 6x20, +PSW 6x50DC Cable length of AC adapter
    1.5 m
    1.5 m
    (137 x 60 x 30)
    11.8 kg
    KDL-43WF80443SU-WL450 *1100x200+PSW 6x20, +PSW 6x50DC Cable length of AC adapter
    1.5 m
    1.5 m
    (137 x 60 x 30)
    9.4 kg
    ZF9 SeriesKD-75ZF975 -400X300 - 2 m 38.5 kg
    KD-65ZF965SU-WL450 *1300X300+PSW 6x20, +PSW 6x501.5 M 28.2 kg
    *1 Use of the rear terminal will be limited depending on the wall mounting style. Refer to the Installation instructions (Wall-Mount Bracket) for the TV.
    2017 models
    Series Name
    Model Name
    Inches
    Screw hole size
    (W x H) mm
    A1 Series
    KD-65A1
    65
    SU-WL450
    400 x 200
    2 m
    29.8 kg
    KD-55A1
    55
    400 x 200
    2 m
    25.0 kg
    XE93xx_XE94xx Series
    KD-75XE9405
    75
    SU-WL845
    400 x 300
    +PSW 6x13, +PSW 6x23
    1.5 m
    42.8 kg
    KD-65XE9305
    65
    SU-WL845
    400 x 300
    1.5 m
    38.2 kg
    SU-WL450 *1
    400 x 300
    KD-55XE9305
    55
    SU-WL840
    300 x 300
    2.5 m
    2.0 m
    287 x 75 x 32.5
    28.6 kg
    SU-WL450 *1
    300 x 300
    XE90xx Series
    KD-75XE9005
    75
    400 x 400
    1.5 m
    33.2 kg
    KD-65XE9005
    65
    SU-WL450 *1
    300 x 300
    2.5 m
    2.0 m
    287 x 75 x 32.5
    22.0 kg
    KD-55XE9005
    55
    300 x 300
    1.5 m
    228 x 75 x 38
    16.9 kg
    KD-49XE9005
    49
    SU-WL450 *1
    200 x 200
    1.5 m
    228 x 75 x 38
    12.6 kg
    XE85xx Series
    KD-65XE8505
    65
    SU-WL450 *1
    300 x 300
    1.5 m
    21.0 kg
    KD-55XE8505
    55
    200 x 200
    1.5 m
    18.6 kg
    XE80xx Series
    KD-49XE8005
    49
    SU-WL450 *1
    200 x 200
    1.5 m
    0.5 m
    12.2 kg
    KD-43XE8005
    43
    100 x 200
    1.5 m
    0.5 m
    10.1 kg
    XE70xx Series
    KD-65XE7005
    65
    SU-WL450 *1
    300 x 300
    1.5 m
    20.9 kg
    KD-55XE7005
    55
    300 x 200
    1.5 m
    17.7 kg
    KD-49XE7005
    49
    200 x 200
    1.5 m
    (161 x 68 x 36) or (170 x 85 x 40)
    11.4 kg
    KD-43XE7005
    43
    100 x 200
    1.5 m
    161 x 68 x 36
    9.3 kg
    KD-65XE7003
    65
    300 x 300
    1.5 m
    20.9 kg
    KD-55XE7003
    55
    300 x 200
    1.5 m
    17.7 kg
    KD-49XE7003
    49
    200 x 200
    1.5 m
    0.5 m
    11.4 kg
    KD-43XE7003
    43
    100 x 200
    1.5 m
    0.5 m
    161 x 68 x 36
    9.3 kg
    KD-65XE7002
    65
    300 x 300
    1.5 m
    20.9 kg
    KD-55XE7002
    55
    300 x 200
    1.5 m
    17.7 kg
    KD-49XE7002
    49
    200 x 200
    1.5 m
    0.5 m
    11.4 kg
    KD-43XE7002
    43
    100 x 200
    1.5 m
    0.5 m
    161 x 68 x 36
    9.3 kg
    KD-55XE7000
    55
    300 x 200
    1.5 m
    17.7 kg
    KD-49XE7000
    49
    200 x 200
    1.5 m
    0.5 m
    11.4 kg
    KD-43XE7000
    43
    100 x 200
    1.5 m
    0.5 m
    161 x 68 x 36
    9.3 kg
    WE75x Series
    KDL-49WE753
    49
    SU-WL450 *1
    200 x 200
    1.5 m
    0.5 m
    (155 x 63 x 32) or (153 x 51 x 35)
    11.5 kg
    KDL-43WE753
    43
    100 x 200
    1.5 m
    0.5 m
    9.1 kg
    KDL-49WE755
    49
    200 x 200
    1.5 m
    (157 x 65 x 32) or (151 x 65 x 32)
    11.5 kg
    KDL-43WE755
    43
    100 x 200
    1.5 m
    9.1 kg
    KDL-49WE750
    49
    200 x 200
    1.5 m
    0.5 m
    11.5 kg
    KDL-43WE750
    43
    100 x 200
    1.5 m
    0.5 m
    9.1 kg
    WE61x_WE66x Series
    KDL-49WE665
    49
    SU-WL450 *1
    200 x 200
    1.5 m
    11.4 kg
    KDL-40WE665
    40
    100 x 200
    1.5 m
    0.5 m
    8.1 kg
    KDL-49WE663
    49
    200 x 200
    1.5 m
    0.5 m
    11.4 kg
    KDL-40WE663
    40
    100 x 200
    1.5 m
    (129 x 56 x 34) or (110 x 63.5 x 31)
    8.1 kg
    KDL-49WE660
    49
    200 x 200
    1.5 m
    0.5 m
    11.4 kg
    KDL-40WE660
    40
    100 x 200
    1.5 m
    0.5 m
    8.1 kg
    KDL-32WE615
    32
    100 x 200
    1.5 m
    0.5 m
    5.8 kg
    KDL-32WE613
    32
    100 x 200
    1.5 m
    5.8 kg
    KDL-32WE610
    32
    100 x 200
    1.5 m
    0.5 m
    5.8 kg
    RE4xx Series
    KDL-40RE453
    40
    SU-WL450 *1
    100 x 200
    1.5 m
    8.1 kg
    KDL-40RE455
    40
    100 x 200
    1.5 m
    0.5 m
    8.1 kg
    KDL-40RE450
    40
    100 x 200
    1.5 m
    0.5 m
    8.1 kg
    KDL-32RE403
    32
    100 x 200
    1.5 m
    5.8 kg
    KDL-32RE405
    32
    100 x 200
    1.5 m
    0.5 m
    5.8 kg
    KDL-32RE400
    32
    100 x 200
    1.5 m
    0.5 m
    5.8 kg
    2016 models
    Series Name
    Model Name
    Inches
    Screw hole size
    (W x H) mm
    ZD9 Series
    KD-100ZD9
    100
    600 x 400
    2.0 m
    118.6 kg
    KD-75ZD9
    75
    400 x 300
    1.5 m
    41.3 kg
    KD-65ZD9
    65
    SU-WL450 *1
    400 x 300
    1.5 m
    32.0 kg
    XD93xx_XD94xx Series
    KD-75XD9405
    75
    Wall-Mount Bracket accessories supplied with your TV
    400 x 300
    1.5 m
    38.7 kg
    KD-65XD9305
    65
    SU-WL450 *1
    300 x 200
    2.5 m
    2.0 m
    287 x 75 x 32.5
    28.9 kg
    KD-55XD9305
    55
    SU-WL450 *1
    300 x 200
    2.5 m
    2.0 m
    287 x 75 x 32.5
    22.0 kg
    XD85xx Series
    KD-85XD8505
    85
    400 x 300
    1.5 m
    60.2 kg
    KD-75XD8505
    75
    400 x 300
    1.5 m
    33.4 kg
    KD-65XD8505
    KD-65XD8577
    KD-65XD8599
    65
    SU-WL450 *1
    300 x 300
    1.5 m
    20.3kg
    KD-55XD8505
    KD-55XD8577
    KD-55XD8588
    KD-55XD8599
    55
    200 x 200
    1.5 m
    0.5 m
    192 x 80 x 32
    15.1kg
    XD83xx Series
    KD-49XD8305
    49
    SU-WL450 *1
    200 x 300
    1.5 m
    192 x 80 x 32
    13.2 kg
    KD-43XD8305
    43
    100 x 200
    1.5 m
    12.3 kg
    XD80xx Series
    KD-55XD8005
    55
    SU-WL450 *1
    200 x 200
    1.5 m
    192 x 80 x 32
    14.7 kg
    KD-49XD8005
    KD-49XD8077
    KD-49XD8088
    KD-49XD8099
    49
    200 x 300
    1.5 m
    0.5 m
    192 x 80 x 32
    13.2 kg
    KD-43XD8005
    KD-43XD8077
    KD-43XD8088
    KD-43XD8099
    43
    100 x 200
    1.5 m
    12.3 kg
    XD75xx Series
    KD-65XD7504
    KD-65XD7505
    65
    SU-WL450 *1
    300 x 300
    1.5 m
    21.5 kg
    XD70xx Series
    KD-55XD7004
    KD-55XD7005
    55
    SU-WL450 *1
    200 x 200
    1.5 m
    16.9 kg
    KD-49XD7004
    KD-49XD7005
    49
    200 x 200
    1.5 m
    13.2 kg
    SD85xx_SD80xx Series
    KD-65SD8505
    65
    SU-WL450 *1
    300 x 200
    1.5 m
    29.4 kg
    KD-55SD8505
    55
    200 x 200
    1.5 m
    226 x 75 x 38
    21.4 kg
    KD-50SD8005
    50
    200 x 200
    1.5 m
    192 x 80 x 32
    16.7 kg
    2015 models
    Series Name
    Model Name
    Inches
    Screw hole size
    (W x H) mm
    X93xxC_X94xxC Series
    KD-75X9405C
    75
    400 x 300
    1.5 m
    56.0 kg
    KD-65X9305C
    65
    SU-WL450 *1
    400 x 300
    1.5 m
    47.3 kg
    KD-55X9305C
    55
    300 x 300
    1.5 m
    37.3 kg
    X90xxC_X91xxC Series
    KD-75X9105C
    75
    400 x 300
    Easy Wall Hanging
    1.5 m
    33.7 kg
    KD-65X9005C
    65
    300 x 300
    Easy Wall Hanging
    1.5 m
    23.2 kg
    KD-55X9005C
    55
    300 x 300
    Easy Wall Hanging
    1.5 m
    18.4 kg
    X85xxC Series
    KD-75X8505C
    KD-75X8501C
    75
    400 x 300
    1.5 m
    34.8 kg
    KD-65X8509C
    KD-65X8508C
    KD-65X8507C
    KD-65X8505C
    KD-65X8501C
    65
    SU-WL450 *2
    400 x 300
    1.5 m
    24.1 kg
    KD-55X8509C
    KD-55X8508C
    KD-55X8507C
    KD-55X8505C
    KD-55X8501C
    55
    300 x 300
    1.5 m
    19.9 kg
    X83xxC Series
    KD-49X8309C
    KD-49X8308C
    KD-49X8307C
    KD-49X8305C
    KD-49X8301C
    49
    SU-WL450 *2
    300 x 300
    1.5 m
    14.4 kg
    KD-43X8309C
    KD-43X8308C
    KD-43X8307C
    KD-43X8305C
    KD-43X8301C
    43
    200 x 300
    1.5 m
    11.8 kg
    X80xxC Series
    KD-55X8005C
    55
    SU-WL450 *2
    300 x 300
    1.5 m
    17.3 kg
    KD-49X8005C
    49
    200 x 300
    1.5 m
    13.2 kg
    S85xxC Series
    KD-65S8505C
    65
    SU-WL450 *2
    400 x 300
    1.5 m
    30.1 kg
    KD-55S8505C
    55
    300 x 300
    1.5 m
    22.9 kg
    S80xxC Series
    KD-65S8005C
    65
    SU-WL450 *2
    400 x 300
    The wall where the display is attached must have a strength that can withstand 4 times (6 times in some models) the mass of the display. For more details about the required strength of the wall, please refer to the Installation Information (Wall-Mount Bracket) on your TV model page.
    If the strength is insufficient, reinforce it sufficiently. As for the reinforcement of the wall, consult Sony dealers or licensed contractors.
    About Screws
    When attaching the Wall-Mount Bracket to the TV, use the screws supplied with the Wall-Mount Bracket.
    The supplied screws are set with a length of 8 mm to 12 mm from the attachment surface of the Wall-Mount Bracket (thread diameter and screw length are different depending on the Wall-Mount Bracket).
    If you use substitute items other than the supplied screws, the TV may fall and cause bodily injury to someone or damage to the internal parts of the TV.
