Article ID : 00178643 / Last Modified : 02/08/2021
How do I reconnect my Bluetooth device to the TV?
    If you have paired your Bluetooth® device before, you can disconnect it without deleting the paired information. This allows you to reconnect your device to the TV without performing the pairing process again.
    Disconnect a Bluetooth device
    1. On the supplied remote control, press the HOME button.
    2. Select Settings.
    3. The next steps will depend on your TV menu options:
      • Select Remotes & AccessoriesBluetooth settingsRegistered devices → Select the device you want to disconnect → Disconnect.
      • Select Bluetooth settings → Registered devices → Select the device you want to disconnect → Disconnect.
    Reconnect a Bluetooth device
    1. Press the HOME button.
    2. Select Settings.
      • Select Remotes & AccessoriesBluetooth settingsRegistered devices → Select the device you want to disconnect → Connect.
      • Select Bluetooth settings → Registered devices → Select the device you want to disconnect → Connect.
