Article ID : 00165110 / Last Modified : 01/12/2016
How to check the member information and system information when using the Netflix app
    IMPORTANT: This feature is only available on device that use version 3 of the Netflix app . If your device uses a different version of the Netflix app, visit the Netflix website for account information.
    1. Open the Netflix app.
    2. Press the Return button.
    3. Select the Settings icon.
      Settings icon
    From the Settings menu, you can check the following:
    • Member information
      Member information
    • Network information
      Network information
    • Device information
      Device information
    • Check your network
      Check network
    NOTE: Pressing the Display button while watching a Netflix movie will display audio and video playback information.
    Display information
