Article ID : 00149158 / Last Modified : 22/10/2020
The display information is cut-off when streaming from Netflix
    As part of the normal operation of the device, the display information that appears when pressing the Display button on the supplied remote will be cut-off or not fully displayed if the Blu-ray Disc player is connected to the TV using composite video cables. This will occur because the image is stretched to accommodate the lower resolution and formatting caused by this connection. To resolve the issue, use a component cable or an HDMI cable to connect the Blu-ray Disc player to the TV.
