Error: 'We're having trouble playing this title right now. Please try again later or select a different title.' appears when using the Netflix app
This issue may be temporary and may resolve itself after a few minutes. If the issue continues, follow the general troubleshooting steps first.
General troubleshooting steps
- Exit the Netflix app and then try it again.
- Ensure that your internet connection is working properly. If your internet is working properly, wait a few minutes and then try the app again.
- Check for a system software (firmware) update to make sure your device is up-to-date.
If the issue still occurs, follow the steps below according to your device.
Android TV™ devices
- Visit the Netflix Support website for more information.
Other TV models and Network Media Players
- On the supplied remote control, press the HOME button
- Go to Settings.
- Select Network.
- Select Refresh Internet Content.
- Select the Netflix app.
- If the issue still occurs, visit the Netflix Support website for more information.
Blu-ray Disc™ players
- Go to Setup.
- Select Resetting.
- Select Initialize Personal Information.
- Go to the Video icon and Select Internet Video.
- Sign in to your account.
- Reset the device to factory settings. Check your manual for model-specific information on how to perform a factory reset.
- Performing a reset will erase any customized settings on your device. You'll need to set up your device again after the reset.
