Article ID : 00145054 / Last Modified : 11/09/2020Print
How to set up and use the Wi-Fi Direct feature of the TV models
    To set up and use the Wi-Fi Direct feature of the R5xxC series TV, follow the steps below.
    1. Enable the Built-in Wi-Fi setting on your TV.
      1. On the supplied remote control, press the HOME button.
      2. Select Settings.
      3. Select System Settings.
      4. Select Set-up.
      5. Select Network.
      6. Select Built-in Wi-Fi.
      7. Select On.
    2. Turn on the Wi-Fi Direct setting of the TV.
      2. Select Settings.
      4. Select Set-up.
      5. Select Network.
      6. Select Wi-Fi Direct,
      7. Select On.
    3. Display the WPA key of the TV.
      2. Select Settings.
      4. Select Set-up.
      5. Select Network.
      6. Select Wi-Fi Direct Settings.
      7. Press the Options button.
      8. Select Manual.
      9. Select Other Method.
        NOTE: The SSID and the WPA key will be displayed on the TV screen.
      10. On the Wi-Fi setting of the Wi-Fi Direct device, select the SSID of the TV and enter the WPA key displayed on the TV screen as the password.
    NOTE:
    • For more details refer to the manual supplied with your smartphone or tablet.
