Article ID : 00082574 / Last Modified : 14/04/2022Print
How to use the iMediaShare application on an iPhone mobile device with the Wi-Fi Direct feature
    Before you start:
    • For information on how to get the iMediaShare app on your iPhone or iPad, or visit the Apple website or contact your mobile device retailer.
    • Although the iMediaShare software supports various media formats, the example used in this solution will allow you to display photos using Wi-Fi Direct.
    1. Make sure that the Wi-Fi Direct feature has been set up.
    2. From the mobile device applications, select iMediaShare.
      imediashare icon on iOS
    3. Select CAMERA ROLL PHOTOS.
      Camera roll screenshot
    4. Select the folder that contains the desired file.
    5. Select the desired image or file.
      photo library example
    6. Select BRAVIA.
      selecting BRAVIA tv in screen selector
    7. The selected image will display on the TV.
