Article ID : 00076391 / Last Modified : 12/01/2016
Which terminal on the television supports MHL?
    Mobile High-Definition Link (MHL) supporting terminal is labeled as MHL on the television.
    Non 4K models
    • HDMI 1/MHL
    4K models
    • HDMI 2/MHL
    • HDMI 4/MHL
    NOTES:
    • If using mobile devices with 4K resolution, connect the MHL cable directly to the HDMI 2/MHL terminal of the television.
    • 4K resolution requires 4K compatible MHL 3.0 Cable. We recommend to use Sony MHL 3.0 cable, product number DLCMC30.SYH.
