Article ID : 00239801 / Last Modified : 04/02/2020
Personal Computer - Wi-Fi Direct
    Before Connecting
    TV can be connected directly with a Wi-Fi Direct/ Wi-Fi compatible device (e.g. smartphone, PC) that also supports the DLNA push controller function. Content such as photos/ music/ videos on the device can be played on TV. No wireless router (or access point) is required to use this feature.
    • TV and laptop may require the latest system software (firmware) update to activate the Wi-Fi Direct feature.
    • The Wi-Fi Direct feature is not available on all Sony products. To see if your product supports the Wi-Fi Direct feature, check the specifications.
    • Some functions may not be available, depending on the products you are using.
    • Some functions may not be available on some regions/ countries.
    Making a Connection and Playback
    Troubleshooting
