Article ID : 00145054 / Last Modified : 27/06/2019
How to set up and use the Wi-Fi Direct feature of the TV models
To set up and use the Wi-Fi Direct feature of the R5xxC series TV, follow the steps below.
  1. Enable the Built-in Wi-Fi setting on your TV.
    1. On the supplied remote control, press the HOME button.
    2. Select Settings.
    3. Select System Settings.
    4. Select Set-up.
    5. Select Network.
    6. Select Built-in Wi-Fi.
    7. Select On.
  2. Turn on the Wi-Fi Direct setting of the TV.
    2. Select Settings.
    4. Select Set-up.
    5. Select Network.
    6. Select Wi-Fi Direct,
    7. Select On.
  3. Display the WPA key of the TV.
    2. Select Settings.
    4. Select Set-up.
    5. Select Network.
    6. Select Wi-Fi Direct Settings.
    7. Press the Options button.
    8. Select Manual.
    9. Select Other Method.
      NOTE: The SSID and the WPA key will be displayed on the TV screen.
    10. On the Wi-Fi setting of the Wi-Fi Direct device, select the SSID of the TV and enter the WPA key displayed on the TV screen as the password.
NOTE:
  • For more details refer to the manual supplied with your smartphone or tablet.
