Article ID : 00146558 / Last Modified : 22/01/2019
How to set up and use the Wi-Fi Direct feature for 2014 TV models
To set up and use the Wi-Fi Direct feature for 2014 TV models, follow the steps below.
  1. Enable the Built-in Wi-Fi setting on your TV.
    1. On the supplied remote control, press the HOME button.
    2. Select Settings.
      HOME > My Apps
      NOTE: The appearance of the Home menu may be different depending to the TV or personalised settings.
    3. Select System Settings or Network.
      NOTE: If the TV shows Network, skip to step 6.
    4. Select Setup.
    5. Select Wi-Fi Setup.
    6. Select Built-in Wi-Fi.
      Built-in Wi-Fi
    7. Select ON.
  2. Turn on the Wi-Fi Direct setting of the TV.
    2. Select Settings.
    4. Select Setup.
    6. Select Wi-Fi Direct.
      Wi-Fi Direct
    7. Select ON.
  3. Display the WPA key of the TV.
    2. Select Settings.
    4. Select Setup.
    6. Select Wi-Fi Direct Settings.
      Wi-Fi Direct settings
    7. Press the Options button.
      Wi-Fi Direct Options
    8. Select Manual.
      Other manuals
    9. Select Other Method.
      Other Method
      NOTE: The SSID and the WPA key will be displayed on the TV screen.
    10. On the Wi-Fi setting of the Wi-Fi Direct device, select the SSID of the TV and enter the WPA key displayed on the TV screen as the password.
NOTES:
