Article ID : 00082574 / Last Modified : 29/03/2019
How to use the iMediaShare application on an iPhone mobile device with the Wi-Fi Direct feature
    IMPORTANT:
    • For information on how to get the iMediaShare app on your iPhone mobile digital device visit the Apple website at http://www.apple.com or contact your iPhone retailer.
    • Although the iMediaShare software supports various media formats, the example used in this solution will allow you to display photos using Wi-Fi Direct.
    1. Make sure that the Wi-Fi Direct feature has been set up on your TV.
    2. From the Apple® iPhone mobile digital device applications, select Settings, then Location Services, and select iMediaShare. Press the Home Button to exit once the setting is complete.
    3. From the Apple® iPhone mobile digital device applications, select iMediaShare. Image
    4. Select My Photos. ImageNOTE: Music, or My Videos can also be selected to view other supported media types.
    5. Select the folder that contains the desired file. Image
    6. Select the desired image or file. Image
    7. Select BRAVIA. Image
    8. The selected image will display. Image
