Article ID : 00061343 / Last Modified : 05/08/2019
Wall mounting - What are the VESA dimensions of my TV (2009-2016 models)
Instead of putting your TV on a piece of furniture, you may want to hang it to the wall. In that case, you will need a wall mount.
Vesa Holes
Look for the four mounting holes on the back of your TV. Take both a horizontal (A) and vertical measurement (B), in mm. These are your VESA dimensions, as shown in the tables below.
BRAVIA 2016 Models
 For instructions on using a Sony Wall-Mount Bracket, please refer to the "Wall-Mount Bracket Installation Guide" leaflet supplied with the wall-mount bracket.
ModelA (mm)B (mm)Note
 KDL-
 32RD43x
 40RD45x
 200 200
                   Compatible Sony Wall Mount Bracket: SU-WL450 (Optional).
 KDL-
 32WD60x
 40WD65x
 48WD65x
 200 200
 KDL-
 32WD75x
 43WD75x
 49WD75x
 300 200
 KD-
 49XD700x
 55XD700x
 200 200
 KD-
 65XD750x
 300 300
 KD-
 43XD80xx
 100 200
 KD-
 49XD80xx
 200 300
 KD-
 55XD8005
 200 200
 KD-
 43XD8305
 100 200
 KD-
 49XD8305
 200 300
 KD-
 55XD85xx
 200
 200
 KD-
 65XD85xx
 300 300
 KD-
 75XD850x
 85XD850x
 400 300
 KD-
 50SD8005
 200 200
 KD-
 55SD8505
 200
 200
 KD-
 65SD8505
 300 200
 KD-
 55XD9305
 65XD9305
 300 200
Sony Wall-Mount Bracket supplied with the TV.
For more information see the following PDF: Wall-Mount Bracket Installation Guide
 KD-
 75XD9405
 400 300
 KD-
 65ZD9
 400 300
 KD-
 75ZD9
 400 300
BRAVIA 2015 Models
 For instructions on using a Sony Wall-Mount Bracket, please refer to the "Wall-Mount Bracket Installation Guide" leaflet supplied with the wall-mount bracket. The Wall-Mount Bracket Installation Guide is also available in your local language from downloadable manuals on this support page.
You can also find the guide for your product by:
  • Selecting your product > Selecting [Manuals] tab > [View all available manuals] > and then choosing the guide for wall-mount bracket installation
KDL-
32R40xC
32R45xC
40R45xC
32R50xC
40R55xC
48R55xC
200200
KD-43X8305C200300
KDL-
32W705C
40W705C
48W705C
300200
KD-
49X8305C
55X8505C
55X9005C
65X9005C
55X9305C
300300
KDL-
43W755C
50W755C
55W755C
43W805C
50W805C
55W805C
65W855C
75W855C
KD-
65X8505C
75X8505C
65X9305C
75X9405C
400300
 KD-
55X9000C
65X9000C
55X9005C
65X9005C
   You can use your TV's stand as part of the Wall-Mount Bracket (parts supplied with the set).
You can also refer to the following video: Sony BRAVIA - How to hang your X90C series on the wall
BRAVIA 2014 Models
KDL-
32W70xB
42W70xB
42W80xB
42W81xB
42W82xB
50W70xB
50W80xB
50W81xB
50W82xB
200100
For instructions on using a Sony Wall-Mount Bracket, please refer to the “Wall-Mount Bracket Installation Guide” leaflet supplied with the wall-mount bracket. The Wall-Mount Bracket Installation Guide is also available in your local language from downloadable manuals in this support page.
VESA adapter (Sony SUWA1) (Accessory, not supplied with TV) is required for VESA installation
Note: Insert CAM and Smart card to TV before installing the VESA adapter to TV.
Vesa Adapter
KDL-32R41xB
32R43xB
40R45xB
40R48xB
200200
KD-49X8505B
55X8505B
55X9005B
KDL-55W805B
55W815B
55W82xB
55W955B
60W605B
60W855B
200200
KDL-
40W605B
48W585B
48W605B
300200
KD-65X8505B
65X9005B
79X9005B
65S9005B
79S9005B
KDL-65W955B
400300
KD-
85X9505B
400400
BRAVIA 2013 Models
KDL-
24W605A
N/AN/A
KDL-24W605A is not VESA compatible.
KDL-
32W60xA
32W65xA
42W65xA
50W656A
50W685A
200100
VESA adapter (Sony SUWA1) (Accessory, not supplied with the TV) is required for VESA installation
Vesa Adapter
KDL-32R42xA100100
KDL-40R47xA200100
KDL-46R47xA300300Before installing the Wall-Mount Bracket, attach the Attachment parts for Wall-Mount Bracket (parts supplied with the set) to the rear of the TV, using the supplied screws. Please refer to the instruction manual.
KDL-40W90xA200300
KDL-42W80xA
46W90xA
47W80xA
55W80xA
55W90xA
KD-55X9005A
300300
KDL-65W855A
KD-65X9005A
400300
BRAVIA 2012 Models
KDL-xxEX440, KDL-xxEX55x, KDL-xxEX65x, KDL-xxHX75x,KDL-xxHX85x, KDL-xxHX95x
Screen sizeA (mm)B (mm)
22"100100
26"200100
32"200200
40"
46"
55"
300300
65"400300
BRAVIA 2011 Models
KDL-xxEX310, KDL-xxEX32x, KDL-xxEX42x, KDL-xxEX52x, KDL-xxEX72x, KDL-xxCX52x, KDL-xxNX72x, KDLxxHX72x, KDL-xxHX82x, KDL-xxHX92x
26"200100
32"200200
40"
46"
52"
55"
300300
60"400300
BRAVIA 2010 Models
KDL-xxEX30x, KDL-xxEX40x, KDL-xxEX50x, KDL-xxEX60x, KDL-xxEX70x,
KDL-xxNX50x, KDL-xxNX70x, KDL-xxNX80x, KDL-xxHX70x, KDL-xxHX80x,
KDL-xxHX90x,
KDL-xxLX90x
22"100100
26"200100
32"200200
37"
40"
46"
52"
300300
55"
65"
400300
BRAVIA 2009 Models
KDL-xxS5500, KDL-xxS56xx, KDL-xxV5500, KDL-xx V5800, KDL-xxW5500,
KDL-xxW57xx, KDL-xxW58xx, KDL-xxZ5500, KDL-xxZ5800, KDL-xxE5500,
KDL-xxS5500, KDL-xxWE5
26"200100
32"200200
37"
40"
46"
52"
300300
