Article ID : 00115215 / Last Modified : 30/03/2022
How do I tune or retune my Sony's Android TV (Cable/Terrestrial)?
    The below procedure applies to all of our Sony's Android televisions. However, depending on your TV model, slight differences between the layout of the remote control and the menu interface may occur.
    If you need further guidance at any point, you can find out more information in your TV's built-in Help Guide, or by navigating to the Support-page of your TV model.
     Remote directions Remote directions
    Use the arrow buttons on your remote to navigate around the TV menu.Select options by pressing the "plus" button. This is the round button in the centre of the circular Menu area of your remote.
    Analogue tuning
    1. Press the [HOME] button of your remote controller.
    2. Go to the Settings menu, located at the bottom of the Home screen.
      Remote directions
      For Android 8.0 Oreo (OSV-O), the Settings icon settings icon is located in the top right-hand corner.
    3. Select Channel SetupAnalogue SetupAnalogue Auto Tuning.
    4. When asked "Do you want to start Auto Tuning?", select Yes.
    The TV will now start tuning. A confirmation message will appear once completed.
    Digital tuning
      Remote directions
    3. Select Channel SetupDigital SetupDigital TuningDigital Auto Tuning.
    5. Make your selection between Antenna or Cable.
      When selecting Antenna the auto tuning for Antenna starts at this point
    6. If Cable was selected in the previous step, the menu for Cable tuning will now appear.
      You may choose to set Scan Type, Frequency or Network ID manually according to specific network parameters, received from your broadcast provider.
      If you have not received anything, we recommend to use the default settings:
      Scan type: Quick scan
      Frequency: Auto
      Network ID: Auto
      Operator: Select the name of your broadcast provider from the list
      If the scan does not find any or all channels, you may try to change the Scan Type setting to Full scan.
      IMPORTANT: It may take an hour, or longer, when selecting Full scan to tune your TV.
      NOTE: If you have problems with the Cable tuning procedure, please check with your provider as they may use different settings.
    7. Proceed by selecting Start.
