Article ID : 00239917 / Last Modified : 15/01/2020
Headphones - Headphone cable
    Connecting headphones with a wired
    NOTE: If the length of the headphone cable is not enough, prepare a separately sold extension cable.
    Connect the headphones to the TV.
    Firmly insert the headphone cable into the headphone terminal indicated by AUDIO OUT / (headphones) on the back of the TV.
    NOTE: The location and label of the terminal indicated by AUDIO OUT / (headphones) differ depending on the model. For details, refer to the Operating Instructions.
    E.g. Back view of KD-49XG9005
    Examples of terminal positions
    • [A]: AUDIO OUT / (headphones) terminal
    • [B]: Headphone cable
    • NOTE: Use a 3-pole stereo mini plug in the AUDIO OUT / (headphones) terminal of the TV.
    A message indicating that connection is complete is displayed on the TV screen.
    When you insert the headphone cable into the headphone terminal, a message indicating that headphones are connected is displayed at the bottom of the TV screen.
    NOTE: A message may not be displayed depending on the model.
    Check if audio from a TV program or connected device is output from the headphones.
