Article ID : 00096609 / Last Modified : 05/11/2014
How do I watch a Blu-ray Disc movie Mastered in 4K on a Sony 4K TV?
    Follow these steps when playing a Blu-ray Disc movie that has been Mastered in 4K  on a Sony BRAVIA 4K TV.
    1. Make sure that the Blu-ray Disc player is connected to the TV using an HDMI cable.
    2. From the menu of the Blu-ray Disc player, set the video output to 1080P/24P.
      NOTE: Refer to the manual supplied with the Blu-ray Disc player for model-specific information regarding how to adjust this setting.
    3. If using a Blu-ray Disc player that has the 4K upscaling feature, turn the setting off.
    4. From the Options menu of the TV set the Scene Select setting to Cinema.
      1. Using the TV remote, press the Options button.
      2. Select Scene Select.
      3. Select Cinema.
    Selecting Cinema will automatically cause the Mastered in 4K setting to turn on.
    You can also change the Mastered in 4K setting from the picture menu. Please press the Options button on the remote, select picture and scroll down to select Mastered in 4K.
