Article ID : 00200442 / Last Modified : 03/12/2019
How to reduce input lag for HDR video games
    IMPORTANT: This article applies only to specific products and/or operating systems. Check the Applicable Products and Categories section of this article before starting these steps.
    When you're playing HDR video games and using an HDMI input on your TV, make sure you select the appropriate HDMI input on your TV. Then, depending on the type of TV you have, please follow the correct steps below.
    NOTE: Before performing the steps, make sure that the TV has the latest software version installed.
    For Sony's Android TVs released after 2016 except XD93, XD94, XD85 and SD85 Series:
    Turn on the Game mode on the TV.
    1. Press the ACTION MENU button on the remote control.
    2. Select Picture or Picture adjustments.
    3. Select Game in Picture mode.
    For Sony's Android TVs released in 2015 and XD93, XD94, XD85 and SD85 Series:
    Turn off the Motionflow on the TV.
    3. Select Advanced settings.
    4. Under Motion, select Motionflow.
    5. Select Off.
