Article ID : 00177806 / Last Modified : 04/07/2019
Wall mounting - compatible Wall-Mount Brackets and screw hole distance measurements for BRAVIA TV (2015-2018 models)
Please see the following chart and check the compatible Wall-mount Bracket for your TV.
WARNING: There is a risk of personal injury.
  • For product protection and safety reasons, Sony recommends that the mounting of your TV on the wall is performed by Sony dealers or licensed contractors.
  • For Safety reasons and to ensure a correct installation, please follow the Wall-mount Bracket Operation Instructions, the TV Setup Guide and the following instructions.
To see the compatibility chart
Compatibility chart
About the Strength of Walls
About Screws
  • The screw hole distance measurements: Width x Height expressed in mm
    The diagram shows the rear side of the BRAVIA TV.
    back side of the BRAVIA TV
    [A] W (width)
    [B] H (height)
    [C] screw holes
    NOTE:
    • In some models of BRAVIA TV, the screw hole distance measurements (W x H) conform to the VESA Mount Standard, but the number and depth of the screw holes do not.
    • Sony cannot guarantee the use of a third party wall mount bracket to mount the BRAVIA TV.
    • For more detailed information and precautions about wall mounting, see the manuals of your TV and wall mount bracket.
  • AC Power adapter size: Width x Height x Depth expressed in mm
    An AC Power adapter comes with some models. The diagram shows the AC Power adapter size compatibilities (W x H x D) in the Compatibility chart.
    Ac Power adapter size
    [A] W (width)
    [B] H (height)
    [C] D (depth)
Compatibility chart
2018 models
Series Name
Model Name
Inches
Compatible Wall-Mount Bracket
Screw hole size
(W x H) mm
Screws (Supplied with Wall-Mount Bracket)
Length of power cord (mains lead)
Weight of TV without Stand
AF8 SeriesKD-65AF865SU-WL450 *1300x300+PSW 6x20, +PSW 6x502 m24.4 kg
KD-55AF855SU-WL450 *1300x200+PSW 6x20, +PSW 6x502 m18.7 kg
AF9 SeriesKD-65AF965SU-WL450 *1400x200+PSW 6x20, +PSW 6x502 m27.2 kg
KD-55AF955SU-WL450 *1400x200+PSW 6x20, +PSW 6x502 m23.8 kg
XF9005 SeriesKD-75XF900575-400x300-1.5 m35.0 kg
KD-65XF900565SU-WL450 *1300x300+PSW 6x20, +PSW 6x501.5 m24.5 kg
KD-55XF900555SU-WL450 *1300x300+PSW 6x20, +PSW 6x501.5 m18.2 kg
KD-49XF900549SU-WL450 *1200x200+PSW 6x20, +PSW 6x501.5 m13.6 kg
XF8796 SeriesKD-65XF879665SU-WL450 *1300x300+PSW 6x20, +PSW 6x501.5 m25.6 kg
KD-55XF879655SU-WL450 *1300x200+PSW 6x20, +PSW 6x501.5 m19.1 kg
KD-49XF879649SU-WL450 *1200x200+PSW 6x20, +PSW 6x50DC Cable length of AC adapter
1.5 m
Length of AC Power Cord
0.5 m
AC Power adapter size (W x H x D)
(170 x 85 x 40) or (191 x 80 x 39)
13.2 kg
KD-43XF879643SU-WL450 *1100x200+PSW 6x20, +PSW 6x50DC Cable length of AC adapter
1.5 m
0.5 m
10.8 kg
XF8599 SeriesKD-65XF859965SU-WL450 *1300x300+PSW 6x20, +PSW 6x501.5 m25.6 kg
KD-55XF859955SU-WL450 *1300x200+PSW 6x20, +PSW 6x501.5 m19.1 kg
KD-49XF859949SU-WL450 *1200x200+PSW 6x20, +PSW 6x50DC Cable length of AC adapter
1.5 m
0.5 m
13.2 kg
KD-43XF859943SU-WL450 *1100x200+PSW 6x20, +PSW 6x50DC Cable length of AC adapter
1.5 m
0.5 m
10.8 kg
XF8596 SeriesKD-85XF859685-400x400-2 m44.1 kg
KD-75XF859675-400x300-1.5 m38.9 kg
KD-65XF859665SU-WL450 *1300x300+PSW 6x20, +PSW 6x501.5 m25.6 kg
KD-55XF859655SU-WL450 *1300x200+PSW 6x20, +PSW 6x501.5 m19.1 kg
KD-49XF859649SU-WL450 *1200x200+PSW 6x20, +PSW 6x50DC Cable length of AC adapter
1.5 m
0.5 m (Russia: 1.5 m)
13.2 kg
KD-43XF859643SU-WL450 *1100x200+PSW 6x20, +PSW 6x50DC Cable length of AC adapter
1.5 m
0.5 m
10.8 kg
XF8588 SeriesKD-65XF858865SU-WL450 *1300x300+PSW 6x20, +PSW 6x501.5 m25.6 kg
KD-55XF858855SU-WL450 *1300x200+PSW 6x20, +PSW 6x501.5 m19.1 kg
KD-49XF858849SU-WL450 *1200x200+PSW 6x20, +PSW 6x50DC Cable length of AC adapter
1.5 m
0.5 m
13.2 kg
KD-43XF858843SU-WL450 *1100x200+PSW 6x20, +PSW 6x50DC Cable length of AC adapter
1.5 m
0.5 m
10.8 kg
XF8577 SeriesKD-65XF857765SU-WL450 *1300x300+PSW 6x20, +PSW 6x501.5 m25.6 kg
KD-55XF857755SU-WL450 *1300x200+PSW 6x20, +PSW 6x501.5 m19.1 kg
KD-49XF857749SU-WL450 *1200x200+PSW 6x20, +PSW 6x50DC Cable length of AC adapter
1.5 m
13.2 kg
KD-43XF857743SU-WL450 *1100x200+PSW 6x20, +PSW 6x50DC Cable length of AC adapter
1.5 m
0.5 m
10.8 kg
XF8505 SeriesKD-65XF850565SU-WL450 *1300x300+PSW 6x20, +PSW 6x501.5 m25.6 kg
KD-55XF850555SU-WL450 *1300x200+PSW 6x20, +PSW 6x501.5 m19.1 kg
KD-49XF850549SU-WL450 *1200x200+PSW 6x20, +PSW 6x50DC Cable length of AC adapter
1.5 m
0.5 m
13.2 kg
KD-43XF850543SU-WL450 *1100x200+PSW 6x20, +PSW 6x50DC Cable length of AC adapter
1.5 m
0.5 m
10.8 kg
XF8305 SeriesKD-70XF830570SU-WL450 *1400x300+PSW 6x20, +PSW 6x501.5 m25.6 kg
KD-60XF830560SU-WL450 *1300x300+PSW 6x20, +PSW 6x501.5 m19.8 kg
XF8096 SeriesKD-55XF809655SU-WL450 *1300x200+PSW 6x20, +PSW 6x501.5 m17.6 kg
KD-49XF809649SU-WL450 *1200x200+PSW 6x20, +PSW 6x50DC Cable length of AC adapter
1.5 m
12.2 kg
KD-43XF809643SU-WL450 *1100x200+PSW 6x20, +PSW 6x50DC Cable length of AC adapter
1.5 m
10.1 kg
XF7596 SeriesKD-65XF759665SU-WL450 *1300x200+PSW 6x20, +PSW 6x501.5 m20.2 kg
KD-55XF759655SU-WL450 *1200x200+PSW 6x20, +PSW 6x501.5 m16.2 kg
KD-49XF759649SU-WL450 *1200x200+PSW 6x20, +PSW 6x50DC Cable length of AC adapter
1.5 m
(158 x 70.5 x 35) or (155 x 67 x 36.5)
12.0 kg
KD-43XF759643SU-WL450 *1100x200+PSW 6x20, +PSW 6x50DC Cable length of AC adapter
1.5 m
9.8 kg
WF805 SeriesKDL-49WF80549SU-WL450 *1200x200+PSW 6x20, +PSW 6x50DC Cable length of AC adapter
1.5 m
1.5 m
(137 x 60 x 30)
11.8 kg
KDL-43WF80543SU-WL450 *1100x200+PSW 6x20, +PSW 6x50DC Cable length of AC adapter
1.5 m
1.5 m
(137 x 60 x 30)
9.4 kg
WF804 SeriesKDL-49WF80449SU-WL450 *1200x200+PSW 6x20, +PSW 6x50DC Cable length of AC adapter
1.5 m
1.5 m
(137 x 60 x 30)
11.8 kg
KDL-43WF80443SU-WL450 *1100x200+PSW 6x20, +PSW 6x50DC Cable length of AC adapter
1.5 m
1.5 m
(137 x 60 x 30)
9.4 kg
ZF9 SeriesKD-75ZF975 -400X300 - 2 m 38.5 kg
KD-65ZF965SU-WL450 *1300X300+PSW 6x20, +PSW 6x501.5 M 28.2 kg
*1 Use of the rear terminal will be limited depending on the wall mounting style. Refer to the Installation instructions (Wall-Mount Bracket) for the TV.
2017 models
Series Name
Model Name
Inches
Screw hole size
(W x H) mm
A1 Series
KD-65A1
65
SU-WL450
400 x 200
2 m
29.8 kg
KD-55A1
55
400 x 200
2 m
25.0 kg
XE93xx_XE94xx Series
KD-75XE9405
75
SU-WL845
400 x 300
+PSW 6x13, +PSW 6x23
1.5 m
42.8 kg
KD-65XE9305
65
SU-WL845
400 x 300
1.5 m
38.2 kg
SU-WL450 *1
400 x 300
KD-55XE9305
55
SU-WL840
300 x 300
2.5 m
2.0 m
287 x 75 x 32.5
28.6 kg
SU-WL450 *1
300 x 300
XE90xx Series
KD-75XE9005
75
400 x 400
1.5 m
33.2 kg
KD-65XE9005
65
SU-WL450 *1
300 x 300
2.5 m
2.0 m
287 x 75 x 32.5
22.0 kg
KD-55XE9005
55
300 x 300
1.5 m
228 x 75 x 38
16.9 kg
KD-49XE9005
49
SU-WL450 *1
200 x 200
1.5 m
228 x 75 x 38
12.6 kg
XE85xx Series
KD-65XE8505
65
SU-WL450 *1
300 x 300
1.5 m
21.0 kg
KD-55XE8505
55
200 x 200
1.5 m
18.6 kg
XE80xx Series
KD-49XE8005
49
SU-WL450 *1
200 x 200
1.5 m
0.5 m
12.2 kg
KD-43XE8005
43
100 x 200
1.5 m
0.5 m
10.1 kg
XE70xx Series
KD-65XE7005
65
SU-WL450 *1
300 x 300
1.5 m
20.9 kg
KD-55XE7005
55
300 x 200
1.5 m
17.7 kg
KD-49XE7005
49
200 x 200
1.5 m
(161 x 68 x 36) or (170 x 85 x 40)
11.4 kg
KD-43XE7005
43
100 x 200
1.5 m
161 x 68 x 36
9.3 kg
KD-65XE7003
65
300 x 300
1.5 m
20.9 kg
KD-55XE7003
55
300 x 200
1.5 m
17.7 kg
KD-49XE7003
49
200 x 200
1.5 m
0.5 m
11.4 kg
KD-43XE7003
43
100 x 200
1.5 m
0.5 m
161 x 68 x 36
9.3 kg
KD-65XE7002
65
300 x 300
1.5 m
20.9 kg
KD-55XE7002
55
300 x 200
1.5 m
17.7 kg
KD-49XE7002
49
200 x 200
1.5 m
0.5 m
11.4 kg
KD-43XE7002
43
100 x 200
1.5 m
0.5 m
161 x 68 x 36
9.3 kg
KD-55XE7000
55
300 x 200
1.5 m
17.7 kg
KD-49XE7000
49
200 x 200
1.5 m
0.5 m
11.4 kg
KD-43XE7000
43
100 x 200
1.5 m
0.5 m
161 x 68 x 36
9.3 kg
WE75x Series
KDL-49WE753
49
SU-WL450 *1
200 x 200
1.5 m
0.5 m
(155 x 63 x 32) or (153 x 51 x 35)
11.5 kg
KDL-43WE753
43
100 x 200
1.5 m
0.5 m
9.1 kg
KDL-49WE755
49
200 x 200
1.5 m
(157 x 65 x 32) or (151 x 65 x 32)
11.5 kg
KDL-43WE755
43
100 x 200
1.5 m
9.1 kg
KDL-49WE750
49
200 x 200
1.5 m
0.5 m
11.5 kg
KDL-43WE750
43
100 x 200
1.5 m
0.5 m
9.1 kg
WE61x_WE66x Series
KDL-49WE665
49
SU-WL450 *1
200 x 200
1.5 m
11.4 kg
KDL-40WE665
40
100 x 200
1.5 m
0.5 m
8.1 kg
KDL-49WE663
49
200 x 200
1.5 m
0.5 m
11.4 kg
KDL-40WE663
40
100 x 200
1.5 m
(129 x 56 x 34) or (110 x 63.5 x 31)
8.1 kg
KDL-49WE660
49
200 x 200
1.5 m
0.5 m
11.4 kg
KDL-40WE660
40
100 x 200
1.5 m
0.5 m
8.1 kg
KDL-32WE615
32
100 x 200
1.5 m
0.5 m
5.8 kg
KDL-32WE613
32
100 x 200
1.5 m
5.8 kg
KDL-32WE610
32
100 x 200
1.5 m
0.5 m
5.8 kg
RE4xx Series
KDL-40RE453
40
SU-WL450 *1
100 x 200
1.5 m
8.1 kg
KDL-40RE455
40
100 x 200
1.5 m
0.5 m
8.1 kg
KDL-40RE450
40
100 x 200
1.5 m
0.5 m
8.1 kg
KDL-32RE403
32
100 x 200
1.5 m
5.8 kg
KDL-32RE405
32
100 x 200
1.5 m
0.5 m
5.8 kg
KDL-32RE400
32
100 x 200
1.5 m
0.5 m
5.8 kg
2016 models
Series Name
Model Name
Inches
Screw hole size
(W x H) mm
ZD9 Series
KD-100ZD9
100
600 x 400
2.0 m
118.6 kg
KD-75ZD9
75
400 x 300
1.5 m
41.3 kg
KD-65ZD9
65
SU-WL450 *1
400 x 300
1.5 m
32.0 kg
XD93xx_XD94xx Series
KD-75XD9405
75
Wall-Mount Bracket accessories supplied with your TV
400 x 300
1.5 m
38.7 kg
KD-65XD9305
65
SU-WL450 *1
300 x 200
2.5 m
2.0 m
287 x 75 x 32.5
28.9 kg
KD-55XD9305
55
SU-WL450 *1
300 x 200
2.5 m
2.0 m
287 x 75 x 32.5
22.0 kg
XD85xx Series
KD-85XD8505
85
400 x 300
1.5 m
60.2 kg
KD-75XD8505
75
400 x 300
1.5 m
33.4 kg
KD-65XD8505
KD-65XD8577
KD-65XD8599
65
SU-WL450 *1
300 x 300
1.5 m
20.3kg
KD-55XD8505
KD-55XD8577
KD-55XD8588
KD-55XD8599
55
200 x 200
1.5 m
0.5 m
192 x 80 x 32
15.1kg
XD83xx Series
KD-49XD8305
49
SU-WL450 *1
200 x 300
1.5 m
192 x 80 x 32
13.2 kg
KD-43XD8305
43
100 x 200
1.5 m
12.3 kg
XD80xx Series
KD-55XD8005
55
SU-WL450 *1
200 x 200
1.5 m
192 x 80 x 32
14.7 kg
KD-49XD8005
KD-49XD8077
KD-49XD8088
KD-49XD8099
49
200 x 300
1.5 m
0.5 m
192 x 80 x 32
13.2 kg
KD-43XD8005
KD-43XD8077
KD-43XD8088
KD-43XD8099
43
100 x 200
1.5 m
12.3 kg
XD75xx Series
KD-65XD7504
KD-65XD7505
65
SU-WL450 *1
300 x 300
1.5 m
21.5 kg
XD70xx Series
KD-55XD7004
KD-55XD7005
55
SU-WL450 *1
200 x 200
1.5 m
16.9 kg
KD-49XD7004
KD-49XD7005
49
200 x 200
1.5 m
13.2 kg
SD85xx_SD80xx Series
KD-65SD8505
65
SU-WL450 *1
300 x 200
1.5 m
29.4 kg
KD-55SD8505
55
200 x 200
1.5 m
226 x 75 x 38
21.4 kg
KD-50SD8005
50
200 x 200
1.5 m
192 x 80 x 32
16.7 kg
2015 models
Series Name
Model Name
Inches
Screw hole size
(W x H) mm
X93xxC_X94xxC Series
KD-75X9405C
75
400 x 300
1.5 m
56.0 kg
KD-65X9305C
65
SU-WL450 *1
400 x 300
1.5 m
47.3 kg
KD-55X9305C
55
300 x 300
1.5 m
37.3 kg
X90xxC_X91xxC Series
KD-75X9105C
75
400 x 300
Easy Wall Hanging
1.5 m
33.7 kg
KD-65X9005C
65
300 x 300
Easy Wall Hanging
1.5 m
23.2 kg
KD-55X9005C
55
300 x 300
Easy Wall Hanging
1.5 m
18.4 kg
X85xxC Series
KD-75X8505C
KD-75X8501C
75
400 x 300
1.5 m
34.8 kg
KD-65X8509C
KD-65X8508C
KD-65X8507C
KD-65X8505C
KD-65X8501C
65
SU-WL450 *2
400 x 300
1.5 m
24.1 kg
KD-55X8509C
KD-55X8508C
KD-55X8507C
KD-55X8505C
KD-55X8501C
55
300 x 300
1.5 m
19.9 kg
X83xxC Series
KD-49X8309C
KD-49X8308C
KD-49X8307C
KD-49X8305C
KD-49X8301C
49
SU-WL450 *2
300 x 300
1.5 m
14.4 kg
KD-43X8309C
KD-43X8308C
KD-43X8307C
KD-43X8305C
KD-43X8301C
43
200 x 300
1.5 m
11.8 kg
X80xxC Series
KD-55X8005C
55
SU-WL450 *2
300 x 300
1.5 m
17.3 kg
KD-49X8005C
49
200 x 300
1.5 m
13.2 kg
S85xxC Series
KD-65S8505C
65
SU-WL450 *2
400 x 300
1.5 m
30.1 kg
KD-55S8505C
55
300 x 300
1.5 m
22.9 kg
S80xxC Series
KD-65S8005C
65
SU-WL450 *2
400 x 300
The wall where the display is attached must have a strength that can withstand 4 times (6 times in some models) the mass of the display. For more details about the required strength of the wall, please refer to the Installation Information (Wall-Mount Bracket) on your TV model page.
If the strength is insufficient, reinforce it sufficiently. As for the reinforcement of the wall, consult Sony dealers or licensed contractors.
About Screws
When attaching the Wall-Mount Bracket to the TV, use the screws supplied with the Wall-Mount Bracket.
The supplied screws are set with a length of 8 mm to 12 mm from the attachment surface of the Wall-Mount Bracket (thread diameter and screw length are different depending on the Wall-Mount Bracket).
If you use substitute items other than the supplied screws, the TV may fall and cause bodily injury to someone or damage to the internal parts of the TV.
