Article ID : 00198496 / Last Modified : 06/02/2020
What are the compatible HDR (High Dynamic Range) formats on Sony's Android TV?
    IMPORTANT: This article only applies to specific products. Please check the Applicable Products banner on the top right-hand side.
    Below is an HDR format compatibility chart:
    Input
    (Service/Device)
     HDR format
    Android TV Model Series
    X93C, X94C, X90C
    S85C, X85C, XD93, XD94, XD85 and
    SD85 Series
    XD75, XD80, XD83,
    SD80, XD70, XE80, XE83,
    XE85, XE90,
    XF75, XF80, XF83, XF85 and XF87 Series
    ZD9, A1
    XE93, XE94, XF90 and AF8 Series
    AF9 and ZF9 Series
    XG80, XG81 and
    XG83 Series
    AG8 and
    XG90 Series
    ZG9, AG9
    XG95 and
    XG85 Series
    Built-in TunerDVB-SHLG
     ✔*1
    Video Streaming
    Services/Apps
    HDR10
     ✔*1 *4
     ✔*1 *4
     ✔*5
    Dolby Vision
     ✔*1 *2
     ✔*2
     ✔*2
     ✔*2
    HLG
     ✔*1 *4
     ✔*1 *4
     ✔*5
    Input TerminalHDMIHDR10
    HLG
     ✔*1
    Dolby Vision
     ✔*1 *3
     ✔*3
     ✔*3
     ✔*3
    USBHDR10
    HLG
     ✔*1
    Dolby Vision
    *1: Will be supported by a software update. For more information on how to update your TV, please refer to: How to perform a software update
    *2: To enjoy Dolby Vision content, the video streaming app/service must support Dolby Vision. For more information, please contact the app/service provider.
    *3: After the Sony TV receives the software update, devices with Dolby Vision playback (such streaming media players and UHD Blu-ray players) that are connected to the Sony TV by HDMI will also require a software update to support Dolby Vision playback through the device. For more information on the timing of an update for a particular player, please contact the player’s manufacturer.
    *4: YouTube HDR (HLG/HDR10) has been supported since December 3rd, 2018. (v2.04.05 or later)
    *5: With the software update, YouTube HDR content is now detected automatically and displayed in HDR format.
    NOTE: S80C, X83C, X80C Series and 2K models released in 2015 are not HDR compatible.
    Overview of each format
    • HDR (High Dynamic Range):
      HDR enables handling of brightness information of a wide dynamic range compared to SDR (standard dynamic range) signals used in normal broadcasts. This reproduces shades in bright areas that tend to have blown out highlights and tones in dark areas that tend to be lost. It allows for reproduction of images with depth and three-dimensional effects that make it feel as if you were seeing it with your own eyes.
    • HLG (Hybrid Log-gamma):
      HLG, as the name suggests, is a “hybrid” format that enables the output of HDR images similar to HDR10 and Dolby Vision. It can also express pictures with well-balanced brightness even in TVs in SDR (standard dynamic range).
    • HDR10:
      HDR10 is a technology standard used with Ultra HD Blu-ray.
    • Dolby Vision:
      One of the HDR technology standards developed by Dolby. It brings scenes to life with striking highlights, deeper darks and vibrant colors. Dolby Vision is an HDR solution that creates an immersive, engaging cinematic experience in your home. For further information, please refer to the following video. https://youtu.be/_vCYV6RWMOU
