Article ID : 00252967 / Last Modified : 04/12/2020
Sound from TV speakers is not in sync with the picture via HDMI
    This issue can occur if the audio format of the HDMI device connected to the TV is set to bitstream output (Dolby Digital, Dolby Digital Plus, DTS, etc.). To fix this, change the audio format of the HDMI device to PCM. Refer to the HDMI device manual for information on how to change the audio format.
    For models with Sound mode settings:
    To improve the audio sync, change the Sound mode of the TV to a setting other than Dolby Audio, such as Standard.
    1. Press the HOME button on the remote control.
    2. Select Settings.
    3. Select Display&SoundSoundSound mode.
