Article ID : 00162298 / Last Modified : 09/09/2021
How do I access Netflix?
    Before you start
    Accessing Netflix on your device
    Some of the Netflix-ready devices include a NETFLIX button on the supplied remote that can be used to launch the app. If the remote for your Netflix ready device doesn't include a NETFLIX button, the app can be accessed by pressing the HOME button and then navigating to the Netflix app. Navigating to the app varies, depending on the device. After pressing the HOME button, check for one of these categories: Apps, My Apps, All Apps, or Applications, to help locate the app on your device.
    Sign in to your Netflix account
    The first time you launch the Netflix app, you must sign in to your account. Your sign-in credentials are retained for accessing the app in the future. If you don't have an account, you will have to sign up for an account with Netflix and select the level of membership you desire.
