Article ID : 00096608 / Last Modified : 25/05/2022
What does it mean when a Blu-ray Disc movie is Mastered in 4K?
    IMPORTANT: This article applies only to specific products and/or operating systems. Check the Applicable Products and Categories section of this article before starting these steps.
    What is Mastered in 4K?
    Sony Pictures Home Entertainment has released Blu-ray Disc movies Mastered in 4K and Optimized for 4K Ultra High Definition Televisions. These Blu-ray Disc movies include the following technologies to yield the greatest possible high definition picture quality, and will upscale to create a satisfying 4K experience:
    • Utilization of 4K movie masters created either from a film source scanned digitally with more than 4K resolution, or shot with 4K digital cameras that provides a more precise and detailed picture.
    • The utilization of x.v.YCC color gamut to the 4K movie master delivers an expanded range of rich color contained in the original source when viewed on a high definition television compatible with x.v.YCC specification.
    • Sony worked together with Sony Pictures to optimize the algorithms of down-converting 4K movie masters to upscale it with the Sony 4K-Reality Pro Engine, when viewed on a 4K LED TV.
    Steps to Activate Mastered in 4K Function
    This function is to optimize and provide picture quality suitable for Blu-ray Discs Mastered in 4K.
    Steps to Activate Mastered in 4K on Your Blu-ray Disc Player
    1. Connect your Blu-ray Disc player to the HDMI input of your TV.
    2. Set the HDMI signal output from your Blu-ray Disc player to 1080/24p.
      1. ON the Blu-ray Disc player's remote control, press the HOME button.
      2. Select Setup.
      3. Select Screen Settings.
      4. Select Output Video Resolution.
      5. Select 1080/24p.
    3. Play any Blu-ray Discs with Mastered in 4K title.
    Steps to Activate Mastered in 4K on Your TV
    NOTE: Steps vary depending on the TV model.
    For TVs Connected to BRAVIA Sync
    1. Choose between Cinema or HDR Video.
      1. On the TV remote control, press the SYNC MENU button.
      2. Select TV Control.
      3. Select Options.
      4. Select Scene Select
      5. Select Cinema or HDR Video.
    2. To activate Mastered in 4K function
      1. On your TV's remote control, press the SYNC MENU button.
      3. Select Home (Menu).
      4. Select Settings.
      5. Select System Settings.
      6. Select Picture.
      7. Select Mastered in 4K.
      8. Select On.
    For TVs Not Connected to BRAVIA Sync
      1. On your remote control, press OPTIONS button.
      2. Select Scene Select.
      3. Select Cinema or HDR Video
      1. On your remote control, press the HOME button.
      2. Select Settings.
      3. Select System Settings.
      4. Select Picture.
      5. Select Mastered in 4K.
      6. Select On.
