Article ID : 00160208 / Last Modified : 11/09/2020
Can I use Bluetooth headphones, speakers, and sound bars with Android TV?
    It depends on the TV model and Bluetooth device.
    For TV models that can be connected to Bluetooth devices through Bluetooth, refer to the following.
    Applicable TV models
    Applicable Bluetooth devices
    Bluetooth headphones and sound bars can only be used with the following TV models. Please make sure that your model is on the list.
    IMPORTANT: A2DP (Bluetooth headphones) functionality is applicable to the following TV series. Please make sure your TV has the latest firmware installed.
    2020 TV Series
    • Z9H
    • ZH8
    • A9
    • A8
    • XH85
    • XH95
    • XH90_91_92
    The sound may skip when a 2020 TV model is connected via Bluetooth to an HT-Z9F/ZF9 Sound Bar if the TV is using the Android™ 8.0 OS.
    To resolve the issue, update the TV to Android 9.0 OS. For how to update, refer to the How to perform a software update article.
    2019 TV Series
    • ZG9
    • AG9
    • AG8
    • XG95
    • XG90
    • XG83 (KD-43/49")
    • XG85 (KD-55/65/75/85") (*1)
    (*1): There may be a delay with the audio when pairing the TV to the HT-X9000F/XF9000 sound bar via Bluetooth.
    2018 TV Series
    • AF9
    • ZF9
    • XF83
    • XF85
    • XF87
    • XF90
    • AF8
    2017 TV Series
    • XE85
    • XE90
    • XE93
    • XE94
    • A1
    NOTES: You can also check the applicable models on our support website or in your TV settings.
    • On our support website, go to the page of your product and refer to the Specifications section. If your model supports Bluetooth headphones, A2DP is displayed in the Bluetooth profile section.
    • Updating to Android 7.0 Nougat is required.
    • You can also check the applicable models on our support website or in the TV settings.
      • Select Settings. This step will vary depending on the options available in your TV menu. Follow the steps accordingly:
        • HOME  Settings  Display & Sound  Audio output.
        • HOME → Settings  Sound.
    • If your model supports Bluetooth headphones, A/V Sync is displayed.
    The following Bluetooth headphones and sound bars are supported.
    IMPORTANT: Other Bluetooth headphones that support A2DP may work with your TV. However, Sony does not guarantee its operation.
    Headphones:
    2020 models
    • WH-1000XM4
    • WF-SP800N
    • WI-SP510
    • WH-CH710N
    • WF-XB700
    2019 models
    • WF-1000XM3
    • WH-XB900N
    • WH-XB700
    • WI-1000XM2
    • WH-H910N
    • WH-H810
    • WF-H800
    2018 models
    • WH-1000XM3
    • WI-C600N
    • WH-CH700N
    • WH-CH500
    • WH-CH400
    • WI-SP600N
    • WI-SP500
    • WI-C300
    2017 models
    • WI-C400
    • WH-1000XM2
    • WH-H900N
    • WH-H800
    • WI-1000X
    • WI-H700
    • MDR-ZX770BN
    • MDR-100ABN
    • MDR-1000X
    • MDR-1ABT
    • MDR-XB650BT
    • MDR-XB950BT
    • MDR-XB950B1
    • MDR-XB950N1
    • MDR-ZX220BT
    • MDR-ZX330BT
    • MDR-EX750BT
    • MDR-XB80BS
    • MDR-XB50BS
    • MDR-XB70BT
    • MUC-M2BT1
    Sound Bar:
    2020 models
    • HT-G700
    • HT-S20R
    2019 models
    • HT-X8500
    • HT-S350
    2018 models
    • HT-Z9F/ZF9
    • HT-X9000F/XF9000 (*1)
    • HT-S200F/SF200
    NOTES:
    • You can only pair one Bluetooth headphone or soundbar and one other Bluetooth device to the TV at the same time, but not two Bluetooth headphones or soundbars at the same time.
    • The codec used when transmitting the Bluetooth audio device is SBC (Sub-Band Coding) (LDAC, AAC, aptX, eSBC, etc., are not supported.)
    • Depending on the TV app used or Bluetooth audio device connected, some app operations performed from the Bluetooth audio device may not work. In such cases, please use the TV remote control to operate the app.
    IMPORTANT: For other Bluetooth devices, if the device supports A2DP, it is highly likely that it can be used. However, Sony does not guarantee the operation as a manufacturer.
    In the event of issues, such as no sound coming out even when using applicable products, refer to the following FAQ:
    Troubleshooting Bluetooth connection with an audio device on Android TV released in 2017.
