Article ID : 00199212 / Last Modified : 28/10/2019
What Android Operating System (OS) version does Sony's Android TV use?
    The Operating System (OS) version on your system depends on your TV model and whether you have done any firmware updates.
    You can check the version by following the steps below:
    1. Press the HOME button on the remote.
    2. Select  Settings.*
    3. Select About in the TV category.
    4. Select Version.
    OS nameOS version number
    Android Marshmallow 6.06
    Android 7.0 Nougat7
    Android™ 8.0 Oreo™8
    *NOTE: For Android Oreo, the settings icon is located in the top right-hand corner.
