Article ID : 00202447 / Last Modified : 22/03/2022
Supported countries/languages and how to use the Google Assistant
    Supported countries/regions/languages
    Google Assistant can be used in the following countries/regions/languages (as of December 2021).
    Country Available Language"OK Google" or "Hey Google"Google Assistant
    Google Assistant when TV is ON
    (Press the microphone button on the remote when the TV is on)
    Screenless mode
    "OK Google" or "Hey Google" when the TV is OFF
    (You can activate the TV by saying "OK Google" or "Hey Google" + command)
    United KingdomEnglishYesYesYes
    FranceFrenchYesYesYes
    GermanyGermanYesYes Not available yet
    SpainSpanishYesYesNot available yet
    ItalyItalianYesYesNot available yet
    IrelandEnglishYesYesNot available yet
    SwedenSwedishYesYesNot available yet
    DenmarkDanishYesNot available yetNot available yet
    NorwayNorwegianYesYesNot available yet
    NetherlandsDutchYesNot available yetNot available yet
    AustriaGermanNot available yetNot available yetNot available yet
    SwitzerlandGermanNot available yetNot available yetNot available yet
    FrenchNot available yetNot available yetNot available yet
    ItalianNot available yetNot available yetNot available yet
    BelgiumDutchNot available yetNot available yetNot available yet
    PortugalPortugueseNot available yetNot available yetNot available yet
    RussiaRussianNot available yetYesNot available yet
    TurkeyTurkishNot available yetNot available yetNot available yet
    PolandPolishNot available yetNot available yetNot available yet
    NOTES:
    • How to use Google Assistant, refer to How to use Google Assistant.
    • Voice search can be used in countries/regions/languages where Google Assistant is unavailable. For details, refer to How do I use the voice search function?
    • The availability of voice search features depends on your TV specifications. For example, your TV set can only respond to "OK Google" or "Hey Google" if it has a built-in microphone, regardless of whether or not this feature is supported in your country.
    • To ensure your TV works as expected, we recommend using the table above to match your TV's country and language settings according to the TV's actual location.
    How to check whether the TV supports Google Assistant
    If the following is displayed when you press the (MIC) button on the remote control, the TV supports Google Assistant.
    • Google Assistant
      The Google Assistant icon and Hints are displayed at the bottom of the screen
      1. Google Assistant icon
      2. Hint
    • Voice search
      The microphone icon is displayed at the bottom of the screen
    Refer to the following articles:
    NOTES:
    • Google Assistant or voice search requires an Internet connection.
    • Google Assistant is not available in certain languages and countries/regions.
