How to use the timer function on your TV
What is the on timer function?
The on timer allows you to let the TV turn on automatically at a specified time. You can use this function to:
- Let the TV turn automatically on when your favourite shows comes on
- Use your TV as an alarm clock
How to set the on timer function?
- Press the HOME button on the remote.
- The next steps will depend on your TV menu options:
- Select Timers.
- Select
Apps — Timers.
- Select Timer or On timer — On.
- Set each item with the arrows and ENTER buttons on the remote.
On time function settings
Selection item | Description of the item |
Timer or On timer | When you select (or check) On, you can set the following items, and the TV turns on automatically at the time you set. |
Day |
Select a day of the week from the following.
Time | Sets the time. |
Duration | The TV automatically turns off after the following set time passed (power standby): You can set 1 hour to 23 hours. |
Input | Select the broadcast or the input source |
Channel | When you select Broadcast, you can select the desired Channel. |
TV on volume or Volume setup | Adjusts the volume of the TV speaker. |
