Unable to display audio or video on the BRAVIA TV from the 4k Ultra HD Blu-ray Disc
The TV does not display video or sound when trying to view a 4K Ultra HD Blu-ray disc.
Make sure to update your 4K Ultra HD Blu-ray Disc™ player to resolve the issue.
If the issue still occurs after the software is updated:
- Disconnect the HDMI cable from your devices.
- Reconnect the HDMI cable.
- Make sure to use Premium High-speed HDMI cable with ethernet that supports 18Gbps.
- Change the 4K Upscale Setting on your device to Auto2.
- On the Blu-ray disc player remote, press the HOME button.
- Select
- Select Setup.
- Select Screen Settings.
- Select 4K Upscale Setting.
- Select Auto2.
