Article ID : 00227387 / Last Modified : 06/12/2019
The Google Assistant or built-in MIC feature cannot be used after changing the language setting
    If you update to the latest software and change the language setting, the Google Assistant may become voice search, or the built-in MIC feature may become unavailable.
    This is because the Google Assistant and “OK Google” detection features are not supported depending on the language.
    From the language setting, select a supported language for each feature.
    NOTE: The display of the language setting will change after updating to the latest software.
    The built-in MIC function is available on some models.
