Article ID : 00206661 / Last Modified : 25/08/2020
How to use the voice search function on your TV
    IMPORTANT: This article applies only to specific products or operating systems:
    The voice search function helps you find the content you are looking for by listening to your vocalised (spoken) search words. In order to use the voice search function, an Internet connection is necessary.
    When you are using an app, search results in the app will be displayed on your TV screen. Below are examples of apps where the voice search function can be used:
    • Google Play Store: You can search apps available in Google Play Store.
    • Google Play Movies & TV: You can search content available in Google Play Movies & TV.
    • YouTube™: You can search content available in YouTube.
    • TV broadcast: TV programs related to your search word are displayed on the TV screen.
    NOTE: If the app you are using is not supported by the voice search function, search results from YouTube content are displayed.
    1. Press the Microphone or Google Assistant button on the TV remote control, depending on your TV model.
    2. Speak into the microphone at the top of the TV remote control, (e.g. a movie title).
    If your model supports eARC:
    *Google, Android, Google Play, YouTube and related logos are trademarks of Google LLC.
