How much storage space is available on my Sony's Android TV?
Your Sony's Android TV will come with a predefined amount of built-in storage. The total amount of free internal space available is 8.2 GB. You can see how much space your apps, videos or images are currently consuming by following these steps:
- Press the HOME button on the remote
- Select [Settings]*
- Select [Storage & reset]
- Select [Storage] to see a list of stored apps, pictures and downloads
NOTES
- Applications may need space for the initial download, and additional space for in-app game content or other data
- You can transfer games and apps to portable storage devices such as USB sticks or hard disk drives (HDDs)
- The screenshots provided here are for reference only. The actual screen might differ slightly according to your country, model or firmware version
- *For Android Oreo (OSV-O), the settings icon
is located in the top right-hand corner
