Article ID : 00160208 / Last Modified : 09/04/2020
Can I use Bluetooth headphones, speakers, and Sound Bars with Android TV?
    It depends on the TV model and Bluetooth device.
    For TV models that can be connected to Bluetooth devices through Bluetooth, refer to the following.
    Applicable TV models
    Applicable Bluetooth devices
    Bluetooth headphones and Sound Bars can only be used with the following models. Please make sure that your model is on the list.
    IMPORTANT: A2DP (Bluetooth headphone) functionality is applicable for the following TV series. Please make sure your TV has the latest firmware installed.
    2020 TV Series
    • XH80
    • XH81
    • XH85
    • XH95
    • X70
    • HX92
    2019 TV Series
    • ZG9
    • AG9
    • AG8
    • XG95
    • XG90
    • XG83 (KD-43/49")
    • XG85 (KD-55/65/75/85") (*1)
    (*1): There may be a delay with the audio when pairing the TV to the HT-X9000F/XF9000 Sound Bar via Bluetooth.
    2018 TV Series
    • AF9
    • ZF9
    • XF83
    • XF85
    • XF87
    • XF90
    • AF8
    2017 TV Series
    • XE85
    • XE90
    • XE93
    • XE94
    • A1
    NOTES: You can also check the applicable models on our support website or in the TV settings.
    • On our support website, go to the page of your product and refer to the Specifications section. If your model supports Bluetooth headphones, A2DP is displayed in the Bluetooth profile section.
    • For the settings menu, go to HOME — Settings — Sound
      OR
      HOME — Settings — Display & Sound — Audio output. If your model supports Bluetooth headphones, A/V Sync is displayed.
    These Bluetooth headphones are supported.
    IMPORTANT: Other Bluetooth headphones that support A2DP may work with your TV. However, we don't guarantee its operation.
    Headphone:
    2019 models
    • WF-1000XM3
    2018 models
    • WH-1000XM3
    • WI-C600N
    • WH-CH700N
    • WH-CH500
    • WH-CH400
    • WI-SP600N
    • WI-SP500
    • WI-C300
    2017 models
    • WI-C400
    • WH-1000XM2
    • WH-H900N
    • WH-H800
    • WI-1000X
    • WI-H700
    • MDR-ZX770BN
    • MDR-100ABN
    • MDR-1000X
    • MDR-1ABT
    • MDR-XB650BT
    • MDR-XB950BT
    • MDR-XB950B1
    • MDR-XB950N1
    • MDR-ZX220BT
    • MDR-ZX330BT
    • MDR-EX750BT
    • MDR-XB80BS
    • MDR-XB50BS
    • MDR-XB70BT
    • MUC-M2BT1
    Sound Bar:
    2019 models
    • HT-X8500
    • HT-S350
    2018 models
    • HT-Z9F/ZF9
    • HT-X9000F/XF9000 (*1)
    • HT-S200F/SF200
    NOTES:
    • Only one Bluetooth audio device can be connected to the TV at a time. It is possible to connect Bluetooth devices other than the Bluetooth audio device at the same time.
    • The codec used when transmitting the Bluetooth audio device is SBC (Sub-Band Coding) (LDAC, AAC, aptX, eSBC, etc., are not supported.)
    • Depending on the TV app used or Bluetooth audio device connected, some app operations performed from the Bluetooth audio device may not work. In such cases, please use the TV remote control to operate the app.
    IMPORTANT: For other Bluetooth devices, if the device supports A2DP, it is highly likely that it can be used. However, Sony does not guarantee the operation as a manufacturer.
    In the event of issues, such as no sound coming out even when using applicable products, refer to the following FAQ:
    Troubleshooting for the Bluetooth connection with the audio device on Android TV released in 2017.
