Article ID : 00248302 / Last Modified : 21/08/2020
Learn about your Sony Android TV: Android Pie Interactive TV Guide
    Android 9 (Pie) Interactive TV Guide
    Get the most out of your TV through Sony's Interactive TV Guide
    Find out how to set up digital channels, configure Wi-Fi, enable Bluetooth and much more.
    Click and discover the many functions of your Sony TV!
    How to use
    This interactive guide allows you to discover the settings and menu options of your Sony Android TV. By selecting a topic and following the on-screen instructions, you will quickly master your TV settings.
    Start using now!
    TV functions
    Checkout the topics for your TV to get you started:
    Getting started
    Apps
    Picture Settings
    Sound Settings
    Network Settings
    Bluetooth / USB / Voice
    System
    Support
    Applicable Series:
    • A8H
    • A9F
    • A9G
    • X75H
    • X80H
    • X85G
    • X85H
    • X90H
    • X95G
    • X95H
    • Z8H
    • Z9F
    • Z9H
    Note: For A9G, X95G, X85G, Z9F, A9F series, TV software version v6.35XX or later version is required. To update your TV software version, click here.
