Article ID : 00202473 / Last Modified : 18/05/2022
Enhanced Audio Return Channel (eARC) support
    By connecting your TV to an eARC supported audio system with an HDMI cable, high-quality sound (that the TV cannot decode by itself) can be passed through to the supported device.
    NOTE:
    • Make sure to use a High-Speed HDMI cable with Ethernet.
    • Your TV doesn't display the eARC connection status. To confirm if eARC is working, try playing an audio format only supported by eARC such as DTS-HD Master Audio or Dolby TrueHD, and then check your sound system display for confirmation.
