Article ID : 00226758 / Last Modified : 27/06/2019
How to switch the input source with your remote control
If you press the INPUT button on the remote control, you will enter the Input source menu. From that menu, you can select the input source you want to display. There are several input sources such as your TV, HDMI connected devices or a USB drive.
You can also use Edit in the menu to add frequently used apps such as Netflix or YouTube. In addition, you can remove inputs and apps that you do not regularly use to create your own personalised menu.
Want to view an example? Let’s go through the motions!
