Article ID : 00226767 / Last Modified : 27/06/2019
Quick settings: how to change TV settings while watching content
If you press the (Quick Settings) button on the remote control, the Settings menu is displayed.
In the menu, select Settings to display a list of settings. You can also make picture and sound adjustments while watching content.
Furthermore, you can use Edit in the menu to add frequently used settings or remove unnecessary ones.
Want to view an example? Let’s go through the motions!
