Article ID : 00239991 / Last Modified : 15/01/2020
Gaming Console
    Before Connecting
    • Make sure your TV has the most recent system software (firmware). System software updates are available for certain LCD Televisions.
    Making a Connection
    1. Follow the steps 1 to 4 below to connect your Game console to your TV.
    2. Turn on your TV and then change the TV channel to HDMI. Make sure the TV is set to the correct video input to receive the HDMI signal. Most TV remotes have an Input button that cycles from one input to the next. Press the Input button repeatedly until the correct HDMI input is displayed on the TV. Be sure to check which input on the TV you are connecting to.
    3. Turn on your Game console by pressing the power button.
    4. (Note for PlayStation 4)
      If you can't get a picture when the PlayStation 4 system is turn on (the power indicator will turn white), simply press the power button for at least 7 seconds (until the system beeps twice) to turn off the power and then turn on the power again.
