Article ID : 00112912 / Last Modified : 05/03/2020
How much storage space is available on my Sony's Android TV?
    Your Sony's Android TV will come with a predefined amount of built-in storage. The total amount of free internal space available is 8.2 GB. You can see how much space your apps, videos or images are currently consuming by following these steps:
    1. Press the HOME button on the remote
    2. Select [Settings]*
    3. Select [Storage & reset]
    4. Select [Storage] to see a list of stored apps, pictures and downloads
    NOTES
    • Applications may need space for the initial download, and additional space for in-app game content or other data
    • You can transfer games and apps to portable storage devices such as USB sticks or hard disk drives (HDDs)
    • The screenshots provided here are for reference only. The actual screen might differ slightly according to your country, model or firmware version
    • *For Android Oreo (OSV-O), the settings icon Settings icon is located in the top right-hand corner
