Article ID : 00199213 / Last Modified : 27/06/2019
What types of USB HDDs (hard disk drives) are compatible with Sony's Android TV?
IMPORTANT: This page introduces compatible information regarding USB HDD drives for Sony's Android TV.
For a BRAVIA TV other than an Android TV, refer to
What types of USB HDDs are compatible with my TV (other than Android TV)?
USB HDDs that can be used with Sony’s Android TVs must meet the following conditions. However, Sony does not guarantee that they will operate. Use them at your own risk.
  • Supported file system and maximum drive size:
    File System
    before connecting
    Max hard disk drive size
    For playback
    (Video/Photo/Music)
    For recording (*1)For storage (*2)
    FAT162GBNot supported2GB
    FAT322TB (*3)4TB (*4)256GB
    exFat16TB4TB (*4)256GB
    NTFS16TB4TB (*4)256GB
    *1: The USB HDD must be registered to the Android TV for recording (to be formatted for recording).
    *2: The USB HDD must be registered to the Android TV as device storage (to be formatted for storage). This function is available in Android OS6 (M) or later.
    • NOTE: The USB HDD size that can be used is 256 GB
*3: The maximum size of a content file that can be saved in the USB HDD is restricted to 4 GB.
*4: A USB HDD up to 16 TB can be connected, but the usable capacity is restricted to 4 TB.
NOTE: Some USB HDDs cannot be used for recording purposes.
Example: USB HDDs with capacities that are too small (less than 32 GB) cannot be used for recording purposes.
  • RPM: No condition
  • Read/Write speed: No condition
  • USB port types and maximum output (current):
    • USB3.1 Gen 1 port: 900 mA MAX. The port is blue.
    • USB2.0 port: 500 mA MAX or 800 mA MAX. For the maximum output of each port, refer to the labels at the back of the TV or the manual.
      NOTE: When recording, connect to the port labeled HDD REC.
      USB port: Max output (current)TV label examplePort image
      USB3.1 Gen 1 port:
      900 mA MAX
      USB 2.0 port:
      500mA MAX, 800mA MAX
NOTE: If a USB HDD is not recognized or cannot be registered even when it is connected, refer to: Cannot recognize or register the USB HDD for recording.
