Android TV does not work properly after software update.
If the issues below occur after a software update, try the applicable solution procedures.
NOTE: If the issues are not resolved even after trying the solution procedures below, return to the page that linked you here and check the other items.
- Sound cuts out regularly
- TV enters demo mode
- Program guide does not display or is outdated
- Recording cannot be performed (*)
- Recorded titles disappeared from the title list (*)
(*) Recording function is only available for certain models and countries/regions.
Check the picture reset mode setting and change it to Off if it is On. -
- Press the Home button on the remote control.
- Select Settings in the System Preferences.
- Select Retail mode settings.
- Select Picture reset mode.
- Set to Off.
Check the demo mode setting and change it to Off if it is On.
To check and configure the setting, refer to How to turn off or exit the DEMO mode on the TV (Android TV / WxxxB series / XxxxB series)
- Program guide does not display or is outdated / Recording cannot be performed
Check the time acquisition setting and change it to On or Use network time if it is Off.
- Using the supplied remote, press the HOME button.
- Select Settings.
- Select Date & Time in the SYSTEM PREFERENCES category.
- Select Automatic date & time.
- Set to On, or set to Use network time.
NOTE: If you select to set to On, set Time synchronization to Use network-provided time.
Check the display setting of the title list.
- Press the TITLE LIST button on the remote control.
If the remote control does not have a TITLE LIST button, press the HOME button, select Title List, and press the Enterbutton.
- Press the ACTION MENU button on the remote control, select Filter, and press the Enter
button.
- If Non-playback or Played is off (no checkmark), press the Enter
button to turn it on (checkmark is displayed).
- Check that the titles are displayed in the Title List.
NOTE: Make sure that ALL is selected as the genre from the menu on the left side of the screen when checking.
