How do I pair the voice command remote control to my TV?
If you are experiencing issues with your remote control, or when you're using the (Mic) button/voice command function on your Voice command remote control, you might be able to solve your issue by unpairing and re-pairing your remote control.
Before you start
- f you replace your voice command remote control, the new remote must be paired again in order to have voice search functionality.
- After updating the software of your TV, the remote may need to be paired again in order to have voice search functionality.
- Pairing can fail if the battery level is too low. If this is the case, replace the batteries with new ones before pairing.
For Android TV™ released in 2016 or later
If you are using this type of remote control, follow these steps:
How to unpair the Voice command remote control from the TV
- Press the HOME button on the remote.
- Select
Settings.
- The next steps will depend on your TV menu options:
- Select Remotes & Accessories → Bluetooth Settings → SONY TV RC MIC 001 or SONY TV VRC 001 → Unpair → OK.
- Select Bluetooth settings → SONY TV RC MIC 001 or SONY TV VRC 001 → Unpair → OK.
How to re-pair the remote control to the TV
- Select
Settings.
Select Remotes & Accessories — Remote control — Connect via Bluetooth or Activate
button.
Select Remote control — Connect via Bluetooth.
Select Voice Remote Control — Activate
button.
Follow the on-screen instructions.
For Android TV released in 2015
If you are using this type of remote control, follow the steps below.
- Using the supplied remote, press the HOME button.
- Select Settings.
- Select Bluetooth setting in the Network & Accessories category.
- Select Device list.
- Select SONY TV REMOTE 001.
- Select Unpair.
- Select OK.
- Select Settings.
- Select Touchpad Remote Control settings in the Network & Accessories category.
- Select Pair Touchpad Remote Control.
- Follow the on-screen instructions.
