Article ID : 00186768 / Last Modified : 03/06/2020
Control your Android TV with Amazon Alexa-enabled devices
    IMPORTANT: This article only applies to specific products, country and/or operating systems. For the applicable products, please check the Applicable Products and Categories section of this article. For the applicable countries/regions and operating systems, please refer to the article below.
    Countries and regions where Sony's Android TV™ supports Amazon Alexa-enabled devices
    What is Alexa
    What is an Alexa Skill and how does it work?
    What is required to control your TV with Amazon Alexa?
    Setup instructions
    Supported TV models
    Supported TV functions
    Related information
    What is Alexa
    Amazon Alexa is the brain that powers devices including Amazon Echo and Echo Dot. It is a cloud-based voice service, and now it allows you to control functions on Sony’s Android TV, such as power on or off, change channels, control volume, and more.
    NOTE: Additional information on Alexa is available at www.amazon.co.uk/meetalexa.
    Skills are capabilities that allow customers to do more with Alexa and personalise their experience—including controlling your Sony Android TV. With this feature, you can use your voice to turn your Android TV on or off, change channels, control volume and more, by asking Alexa through devices such as Amazon Echo and Echo Dot.
    NOTE: Alexa Skills for Sony Android TV control are only supported in the UK.
    • Android TV models that support the Alexa skill (see supported models)
    • Amazon Echo device. Google Home isn't supported
    • Mobile device such as your phone or tablet
    • Amazon account
    • Google account
    • Home network with Wi-Fi capabilities (Dual-band Wi-Fi supports 802.11 a/b/g/n (2.4 and 5 GHz) networks. Doesn't support connecting to ad-hoc (or peer-to-peer) Wi-Fi networks)
    Setup instructions
    Supported TV models
    Supported models have the TV Control Setup with Amazon Alexa app on the Home screen. You do not manually install this app, it will automatically install on supported TVs. If the app is not on the home screen, your TV may not be supported yet. Make sure your TV is set to automatically receive updates.
    2016 Android TVs
    • XD70, XD75, XD80, SD80, XD83 and ZD9 Series
    2017 Android TVs
    • XE80, XE83, XE85, XE90, XE93, XE94 and A1 Series
    2018 Android TVs
    • XF75, XF80, XF83, XF85, XF87, XF90, AF8, AF9 and ZF9 Series
    2019 Android TVs
    • XG80, XG81, XG83, XG85, XG87,  XG90, XG95, AG8, AG9 and ZG9 Series
    Use the following Amazon Alexa voice commands to control your Android TV:
    [ - ] Power ON / OFF
    [ - ] Change channel by number or name
    [ - ] Control volume
    [ - ] Mute or unmute
    [ - ] Change input
    [ - ] Control playback for DVR or streaming content
    NOTES:
    • Indirect commands address an unspecified recipient.
    • Direct and precise commands address a specific recipient.
    • Use the supplied remote control / IR Blaster to allow this feature to work with your set-top box.
    • Details on how to setup the IR Blaster .
     Related information
