Article ID : 00274122 / Last Modified : 30/08/2023Print
How to reset your Sony TV (soft restart, power cycle or factory data reset)
    What TV reset types can I do?
    Reset TypeMy TV is responsiveMy TV is unresponsive
    Soft Reset (Android TV & Google TV)Press & hold the POWER button on the remote to select Restart. Not possible
    Power Cycle (All TVs)Unplug the TV power cord for 30 seconds, then plug it back inUnplug the TV power cord for 30 seconds, then plug it back in
    Factory Data Reset * (All TVs)Access settings, navigate to Factory Data Reset Not possible
    Forced Factory Data Reset (Android TV & Google TV) *
    (Tap to jump to section)
    Use TV buttons (on the TV, not the remote) for a manual resetUse TV buttons (on the TV, not the remote) for a manual reset
    * Remember, a factory reset erases settings and requires setting up the TV again.
    Responsive TV Issues
    If your TV is responsive but has specific issues (app crashes, random turn-offs, etc.), try:
    • Soft Reset (Android TV & Google TV): Press and hold the POWER button until the TV restarts or a menu appears, then select Restart.
    • Power Cycle (All TVs): Unplug the TV power cord for 30 seconds, then plug it back in.
    How to perform a Factory Data Reset
    If previous steps fail, but you can access the settings, perform a Factory Data Reset in the system settings:
    • On the remote control, press the quick settings button(Quick Settings button), HOME button or ACTION MENU button, depending on your TV/remote control.
    • Select the settings cogor arrow.
    • The following steps will vary depending on your TV menu options:
      • Select System → About → Reset → Factory data reset → Erase everything → Yes.
      • Select Device Preferences → Reset → Factory data reset → Erase everything → Yes.
      • Select Storage & reset → Factory data reset → Erase everything → Yes.
    The factory reset may take a few minutes. Wait until the process completes, and the TV will start the initial setup.
    Unresponsive TV Issues
    If your TV is unresponsive (stuck, not powering on, etc.), attempt:
    • Power Cycle (All TVs): Unplug for 30 seconds, then plug back in.
    • Manual Factory Reset (Android TV & Google TV): If settings access is impossible.
    How to perform a Forced Factory Data Reset
    If it's impossible to access the settings with the remote, do a Manual Factory Data Reset using the buttons on the TV.
    Follow the instructions according to the number of buttons on your TV:
    Where to find the power button on your TV?
    Type A: Your TV model has one button
    Type B: Your TV model has three buttons (left, right or back of the TV)
    Type C: Your TV model has more than three buttons
    If the issue persists after following the steps in this article, please get in touch with us.
