Article ID : 00199700 / Last Modified : 24/09/2019
Frequently Asked Questions for the Google Assistant
    IMPORTANT: This article applies only to specific countries/regions/languages that support Google Assistant. For applicable countries/regions/languages, refer to the following article: Supported countries/regions/languages and how to use the Google Assistant.
    What languages does the Google Assistant support?
    How can I change the language on my TV?
    Can I use the Google Assistant if I don't sign-in to my Google account?
    How can I see the command list?
    When can I use the Google Assistant in a different language?
    How to search for broadcast-related content using the Google Assistant
    For more information on how to use the Google Assistant, please see the following:
    Please check the following link:
    Follow these steps to change the language on your TV:
    1. On the supplied TV remote, press HOME.
    2. Select  Settings.
    3. Under System Preferences category, select Language.
    4. Select English.
    Yes, you can use the Google Assistant, but with limited functions only.
    You can check the following link:
    We will announce it when it's ready.
    The Google Assistant can respond to your search request, depending on what you are doing with the TV, such as watching TV programmes or recorded content.
    For instance, if you say a search keyword when watching TV, the Google Assistant will provide a list of TV programmes that match the keyword and are being broadcasted now as well as those in the future. If you say a search keyword when the recorded list is displayed, the Google Assistant will show recorded content that matches the keyword.
    *Google and Android TV are trademarks of Google LLC.
