How to connect or reconnect your wireless or Voice command remote control to your TV
If you are experiencing issues when using a wireless remote control, or when using the (MIC) button/voice command function on your Voice command remote control, follow these steps to unpair and then re-pair the remote control, or perform the remote control pairing:
- If you replace your voice command remote control, the new remote must be paired again in order to have voice search functionality.
- After updating the software of your TV, the remote may need to be paired again in order to have voice search functionality.
- Pairing can fail if the battery level is too low. If this is the case, replace the batteries with new ones before pairing.
For Google TV™ or Android TV™ released in 2016 or later
If you are using this type of remote control, follow these steps:
- Unpair the Voice command remote control from the TV:
NOTE: If your TV is listed below, skip this step.
Target model list- Press the HOME button on the remote.
- Select
Settings.
- The next steps will depend on your TV menu options:
- Select Remotes & Accessories — Bluetooth Settings — SONY TV RC MIC 001 or SONY TV VRC 001.
- Select Bluetooth settings — SONY TV RC MIC 001 or SONY TV VRC 001.
- Select Unpair.
- Select OK.
- Pair or re-pair the Voice command remote control to the TV:
- Open the
Settings screen. How to access Settings
- Select Remotes & Accessories — Remote control — Connect via Bluetooth or Activate
button.
- Select Remote control — Connect via Bluetooth.
- Select Voice Remote Control — Activate
button.
- Follow the on-screen instructions.
NOTE: Pairing can fail if the battery level is too low. If this is the case, replace the batteries with new ones before attempting to pair again.
- Open the
For Android TV released in 2015
If you are using this type of remote control, follow the steps below:
- Unpair the Voice command remote control (Touchpad Remote Control) from the TV:
- Using the supplied remote, press the HOME button.
- Select Settings.
- Select Bluetooth setting in the Network & Accessories category.
- Select Device list.
- Select SONY TV REMOTE 001.
- Select Unpair.
- Select OK.
- Pair or re-pair the Voice command remote control (Touchpad Remote Control) to the TV:
- Select Settings.
- Select Touchpad Remote Control settings in the Network & Accessories category.
- Select Pair Touchpad Remote Control.
