Article ID : 00155907 / Last Modified : 10/09/2020
Can I use the microphone on a smartphone or tablet for the Voice Search function?
    Yes, you can use the microphone of your mobile device for the voice/speech recognition with the following apps:
    For Android™ mobile device
    • Video & TV SideView app
      NOTES:
      • The list of supported devices and OS versions is available on the Video & TV SideView Website.
      • Depending on the model of your TV, you may not be able to use the voice recognition function of Video & TV SideView.
        In such cases, use the supplied remote control or the built-in MIC (only some models have a built-in MIC).
    • Android TV Remote Control
      NOTE: The information about the supported OS version is available on the Android TV Remote Control Website.
    For iOS mobile device
      NOTE: The information about the supported OS version is available on the Android TV Website.
    *Android and Android TV are trademarks of Google LLC
