How do I reconnect my Bluetooth device to the TV?
If you have paired your Bluetooth® device before, you can disconnect it without deleting the paired information. This allows you to reconnect your device to the TV without performing the pairing process again.
Disconnect a Bluetooth device
- On the supplied remote control, press the HOME button.
- Select
Settings.
- The next steps will depend on your TV menu options:
- Select Remotes & Accessories → Bluetooth settings → Registered devices → Select the device you want to disconnect → Disconnect.
- Select Bluetooth settings → Registered devices → Select the device you want to disconnect → Disconnect.
Reconnect a Bluetooth device
- Press the HOME button.
- Select
Settings.
- Select Remotes & Accessories → Bluetooth settings → Registered devices → Select the device you want to disconnect → Connect.
- Select Bluetooth settings → Registered devices → Select the device you want to disconnect → Connect.
