Article ID : 00121556 / Last Modified : 06/01/2021
How to set up and use the Wi-Fi Direct feature of the Android TV with Wi-Fi Direct capable device.
    Please refer following settings:
    IMPORTANT: This is a model-specific solution, view the Applicable Products and Categories for this article to verify that these specifications apply to your model.
    1. Enable the Built-in Wi-Fi setting on your TV.
      1. Using the TV remote control, press the HOME button.
      2. Select Settings.
      3. Select Network in the NETWORK & ACCESSORIES category.
      4. Select Advanced settings.
      5. Select Built-in Wi-Fi, and change to On.
    2. Turn on the Wi-Fi Direct setting of the TV.
      2. Select Settings.
      4. Select Wi-Fi Direct, and change to On.
    3. Display the TV's WPA key.
      2. Select Settings.
      4. Select Wi-Fi Direct.
      5. Select Wi-Fi Direct Settings.
      6. Select  Show Network (SSID)/Password.
      7. The SSID and the WPA key will be displayed on the TV screen.
      8. On the Wi-Fi setting of the Wi-Fi Direct device, select the SSID of the TV and enter the WPA Key displayed on the TV screen as the password.
      9. If the connection is successful, the message Wi-Fi device is connected, is displayed on the TV screen.
        NOTE: For more details refer to the manual supplied with your smartphone or tablet.
