Article ID : 00187124 / Last Modified : 19/09/2018
Install Amazon Alexa App and Setup Android TV Skill
    Follow these steps to install the Alexa app for Android TV:
    1. On your mobile device, open the Google Play™ store and search for the Amazon Alexa app.
    2. Install the Amazon Alexa app.
    3. Open the app.
    4. Sign in with your Amazon account email and password.
    5. After you sign in, select GET STARTED.
    1. On your account, select the menu icon, and then select Skills.
    2. Under the All Skills screen, select Your Skills.
    3. Under Your Skills, select Sony's Android TV.
    4. Under the Sony's Android TV screen, select MANAGE DEVICES IN SMART HOME.
    5. Under Smart Home screen, select Devices.
      NOTE: Alexa will start searching for your device.
